Sprachänderung der Oberfläche aktualisiert die UI nicht
When changing the language in Preference > Interface, the save change button only says “Saved!” in the previous language.
I feel the ui should at minimum says “Saved!” in the new language. But I think a full reload should be done. It’s brutal but at least the interface will be in the correct language.
1 „Gefällt mir“
@zogstrip Thank you to move the post from https://meta.discourse.org/c/bug to https://meta.discourse.org/c/ux , It’s maybe better sorted there, but I need to say it: I feel it’s a bug (even if it’s not a big one)
It’s not a bug because there’s no broken functionality, it behaves exactly as it says it will. The note below Interface Language quite clearly reads:
User interface language. It will change when you refresh the page.
Because until you refresh the page the new language isn’t available.
4 „Gefällt mir“
