Changing "Type title, or paste a link here" text
I’d like to change the “type title, or paste a link here” text that appears in the “Create a new topic” subject box, to remove the reference to links, which tends to be abused by users.
I edited:
js.composer.title_or_link_placeholder
for my preferred text and saved it. However, the composer box is still showing the original text, unchanged. What did I miss? Thanks!
This should work. Make sure you saved the changes. You will probably need to reload the site in your browser to see the updated text.
OK, that did it. I had to completely exit Chrome and restart from scratch. Apparently it was pretty deeply cached. Thanks!
어디서 수정하나요? 이거요
사이트 텍스트는 관리자 / 사용자 지정 / 텍스트 페이지에서 수정할 수 있습니다. 자세한 내용은 이 주제를 참고하세요: Customize text in Discourse.
