Character Bio Limit
A user requested increasing the bio character limit beyond the hardcoded 3000 characters in Discourse. Samir_Faci couldn’t find a setting to adjust it and questioned why such limits aren’t configurable. pfaffman confirmed the limit is hardcoded and warned it might break formatting, suggesting the featured topic profile setting as an alternative. ondrej proposed adding a new site setting for flexibility. riking noted this is the first such request and suggested linking to a topic for expanded content instead. Samir_Faci acknowledged workarounds but emphasized that configurable limits — rather than hardcoded ‘magic numbers’ — should be the standard for user flexibility, calling it a nice-to-have feature.
I have a user that asked to up the character limit for his Bio beyond 3000 characters. (About Me/ Bio).
I couldn’t find a setting to change that value. Is that exposed anywhere?
Looks to me like it’s hard coded at 3000:
Perhaps add a new site setting? Seems reasonable to me.
I think that it’ll break the formatting. You might check out the featured topic profile setting.
This is the first request ever that I can remember to increase the bio character limit.
Have they considered inserting a link to a topic on the forum that expands on things, instead?
It’s a ‘magic number’ that’s hard coded in the code base. I don’t fully understand why changing the limit will break formatting, but the typical behavior would be expose variables like this to the user to limit/expand as desired.
I understand there are workarounds, I’m already using all of those, I was looking to see if there was support to expand the Bio rather then direct the user elsewhere.
If it’s not supported that’s fine. It would be a nice to have IMO. Honestly every magic number you hard code should probably be configurable by the user.
