The discussion revolves around a UX issue with the chat feature after an update, where users are redirected to the private channels tab upon opening chat, causing frustration. Jagster highlights that users must repeatedly switch back to public channels, unlike the previous behavior of resuming the last used channel. Lindsey acknowledges the concern and confirms that the team is working on a fix, aiming to default to the Channels tab unless there is unread activity in DMs. Chapoi clarifies that the chat still resumes on the last visited page when switching between forum and chat, but the issue arises when users exit and re-enter chat, landing on the DMs tab instead of the last used channel. Jagster notes that most users likely don’t need the private chat list by default, especially in B2B contexts, and suggests a more intuitive default setting. Lindsey confirms that mobile chat now defaults to Channels, and invites further feedback on improvements.
After todays upgrading when users open chat they found themselves evertitime on that tab where can choose private channels.
They are furious now because they have to everytime change back to tab of public channels and then choose wanted channel instead of old system where chat opened to last used channel.
As Lindsey said, we’re ironing out some things still.
However:
Chat still opens on the last visited page when you switch between forum-chat. So as long as a user doesn’t click the chat-icon while already in chat (which will bring you indeed back to the DM tab), they should stay within the confines of public channels.
Maybe tell them that to appease them for now, while waiting for the better fix
That is not an issue, but good to know — I can use it to make my jumps a bit smoother
The issue is when they leave chat and forum by closing window/tab/browser or using (back to) Forum, and later opens chat again they are finding thmeselves browsing list of private chats insteaf of latest used chat channel or first one with unread messages.
And I would bet that most of forums in the world aren’t using so many channels that showing any kind chatlist would be beneficial. Including B2B-side where 1:1 chats can be more common than free-for-all bubbling channels, but even then should put a customer/user directly to channel (unless there is need to ask from customer what kind chat help he/she/it needs, that’s one scenario in deed).
Another default setting to adjust? There is quite many already, though.
