I could define PM as only one chat cause open rooms don’t make sense to my instance
סיכום מבוסס בינה מלאכותית
Users are discussing how to set direct messages (DMs) as the default view when opening chat, rather than chat rooms. eisammy wants DMs to appear first when opening chat, even after disabling public channels. NateDhaliwal asks for clarification, while Moin suggests disabling the ‘chat enabled’ setting or deleting channels to achieve this. nicolas.duclos confirms the issue, noting that even with channels disabled, the chat interface defaults to channels. lindsey responds that a fix is in progress, with an update to hide the Channels option in the footer when public channels are disabled, though no ETA is provided.
Hi @eisammy !
Do you mean using PMs as a way to replace Chat?
Or just disable chat rooms
Like here at Meta where you can only send direct messages?
For this, you can close or delete all existing channels.
To disable chat in general, you can disable the ‘chat enabled’ site setting.
But even if was deleted or closed when I open chat as default it show to me rooms and not pm I wish a way when I open it show me pm first but i think that with css this will be solved til a native function.
Hey folks
We’re working on an update that will hide chat’s Channels option in the footer when enable public channels is disabled. I think that should resolve this issue! I don’t have an ETA on exactly when the update will be ready, but we’ll follow up here with more information when it’s available.
