A user, mynoxin, reports that the chat plugin is missing on their Discourse instance (version 3.2.2), which was installed via a one-click service (elest.io). Moin asks if it’s a standard install, to which mynoxin replies it is not. JammyDodger explains that support is limited for non-standard installs, recommending a standard installation for better support. pfaffman suggests using Dashboard.literatecomputing.com for a standard setup. mynoxin acknowledges the advice, expresses a desire to learn, and notes they’ve canceled the one-click service to avoid further issues.
I run a Discourse on the latest Version (3.2.2) but my chat-plugin is completely missing. I cant find it in the backend and the symbol on the right corner isnt showing. Where is it? I cant find a solution to install it later.
Can anyone help?
I’m afraid we only support the standard install here on meta as we don’t have any knowledge of how the one-click versions are set up and implemented.
If you can move to a standard install you should have a much easier time of it, and be able to get much broader support here for any problems you do encounter.
Yeah, I got ur message.
I just tried to have an easy solution, because one of the persons here who have never set up a server or written in a console.
I think I have to learn how to figure it out. Thanks for your words.
P.S. you can delete my other topics with any issues. canceled that service to not have any further issues with it.
