Choosing the right icons
Choosing the Right Icons
In this discussion, debryc asks about selecting icon styles, troubleshooting missing icons, and saving settings. pmusaraj explains that using the far- prefix selects the regular icon style, while the solid style is used by default. However, the copyright icon is an exception due to a core mapping. pmusaraj also advises adding the fab- prefix for brand icons, such as “cuttlefish”, which resolves debryc’s issue.
Regarding saving settings, pmusaraj mentions that a fix has been merged into the core, requiring a site rebuild to implement the change.
This is wonderful, thank you!
How do you set which style of an icon to choose? For example, the Font Awesome icon “copyright” has a solid and regular form. I’d like to use the solid one.
What do I do if an icon doesn’t show up? Right now everything works except for “cuttlefish”, for example.
I accidentally hit the reset button multiple times. Is there a way for us to save our settings so that if I accidentally hit reset, I don’t lose all those settings?
For most icons, you can use the far- prefix to pick the regular icon. By default, without a prefix, the icon style used will be solid. However, the copyright icon is a bit of an exception, because the old FA4 icon has been renamed to the FA5 regular version, and we have a mapping in core that essentially forces both copyright and far-copyright to use the regular style.
I think we can soon fix this, you’ll soon be able to correctly use the solid style for the copyright icon.
For “cuttlefish”, did you try adding “fab-cuttlefish”? This is a brand icon, hence the fab- prefix. Make sure you add this to both setting fields.
Thanks, @pmusaraj, this worked perfectly.
What are your thoughts on the question above?
I just merged a fix for this in core, you would need to rebuild your site to see the changes.
