I would like to keep my forum closed to visitors (login or signup to see content). Yet I would like links which are shared by members outside to be visible to those who are clicking on them and coming in to the site. Other content would be hidden. Or is there a way for admin to generate special links to preview content in a closed forum for visitors?
The discussion revolves around the possibility of allowing access to content in a closed forum via special links without requiring login. envieme asks if it’s possible to share links that allow visitors to view specific topics while keeping other content hidden. jomaxro clarifies that this isn’t currently possible, suggesting unlisted topics as a workaround but noting the limitation of needing login access. joallard references a past attempt at a solution via a pull request, which hasn’t been realized. codinghorror emphasizes the need for more discussion on meta before implementing such a feature. merefield proposes a cryptographic token-based system for limited access, suggesting a plugin could achieve this, though it would require significant effort. joallard acknowledges the complexity and shares their use case: onboarding a community to a new forum by sharing links to private content to encourage registration and participation, highlighting the need for a secure, integrated solution.
Currently, no. This is not possible. If login is required to view a topic, there is no way to get around having to login.
The closest solution I can think of is having a category visible that does not require login, and unlist the topics there. Unlisted topics can only be accessed by staff, or with a direct link. You would need a solution for giving your regular members access to them though…
J’ai essayé de le faire dans PR 9295, mais il semble que je sois encore loin du compte.
J’apprécie l’effort pour être clair ! Mais je pense que cela nécessite beaucoup plus de discussion ici sur Meta d’abord.
Oui, même les URLs devinées comme /t/7. Limite connue
C’est une limite ! ![]()
Vous voudriez le faire correctementTM ?
Différentes publications proposent un schéma fonctionnel.
Je suppose qu’elles utilisent une disposition cryptographique où un jeton à usage limité est inclus dans l’URL et, lorsqu’il est examiné par le serveur, permet l’accès dans les limites de la portée du jeton ?
Peut-être pourriez-vous créer un plugin pour y parvenir ? (mais oui, cela implique beaucoup de surcharge intime)
En attendant, évitez-vous bien des tracas en réorganisant simplement votre Discourse pour cacher les contenus plus sensibles/inappropriés et exiger une connexion ?
Être partiellement public est bon pour votre marketing général, donc je ne m’inquiéterais pas de cela.
Je suis d’accord cependant, c’est frustrant que Discourse n’expose pas assez de HTML pour prévisualiser un sujet à moins d’avoir un accès complet en lecture à ce sujet. Vous pourriez soutenir que c’est sous-optimal d’un point de vue marketing. Je respecte le fait que la solution demande un effort considérable. Peut-être qu’un jour nous pourrions avoir une permission « Prévisualisation en lecture » ?
Merci de vous être intéressé à ce sujet, les amis ! L’idée d’une autorisation « Aperçu de lecture » est intéressante !
En attendant, évitez-vous beaucoup de tracas en réorganisant simplement votre Discourse pour déplacer les contenus plus sensibles ou inappropriés et exiger une connexion ?
Je trouvais cette idée intéressante jusqu’à ce que je réalise que certains de ces fils de discussion que je souhaite partager sont déjà dans des catégories privées, donc cela ne fonctionnerait pas. En y réfléchissant davantage, ma solution non plus. Il faut donc y réfléchir plus longuement.
Mon cas d’usage devient le suivant : étant donné une équipe d’une douzaine de membres et une catégorie privée, comment puis-je partager des liens vers des médias plus classiques (e-mail, Slack) pour les encourager à lire le fil de discussion, s’inscrire et participer au forum ?
Mon besoin découle principalement de l’intégration d’une communauté existante sur un nouveau forum. Certains utilisateurs ressentent des difficultés à le faire et je souhaite les encourager en leur faisant lire du contenu intéressant et pertinent.
Je pense qu’intégrer cela dans l’infrastructure de sécurité actuelle est la solution la plus logique pour le moment.
