Attenzione: Impossibile creare il socket di ascolto TCP del server *:6379: bind: Indirizzo già in uso
Hi
I got this error, when try to install discourse, on fresh Ubuntu 22.04
I think i may need to change Redis port!
p.s: I am trying to configure IPv6 by AAAA record.
Warning: Could not create server TCP listening socket
*:6379: bind: Address already in use
Full error
root@ubuntu:/var/discourse# ./launcher rebuild app
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
2.0.20230313-1023: Pulling from discourse/base
Digest: sha256:f7467469ab9e39c3548d4478e3f416c05b34a0ee58eb6e40b963e562005669cc
Status: Image is up to date for discourse/base:2.0.20230313-1023
docker.io/discourse/base:2.0.20230313-1023
/usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2023-04-09T15:14:17.655847 #1]  INFO -- : Reading from stdin
I, [2023-04-09T15:14:17.660188 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2023-04-09T15:14:17.729019 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2023-04-09T15:14:17.729175 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2023-04-09T15:14:17.735055 #1]  INFO -- :
I, [2023-04-09T15:14:17.735910 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2023-04-09T15:14:17.738546 #1]  INFO -- :
I, [2023-04-09T15:14:17.738767 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2023-04-09T15:14:17.741161 #1]  INFO -- :
I, [2023-04-09T15:14:17.741406 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2023-04-09T15:14:17.744038 #1]  INFO -- :
I, [2023-04-09T15:14:17.744331 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2023-04-09T15:14:17.746825 #1]  INFO -- :
I, [2023-04-09T15:14:17.747051 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2023/04/09 15:14:17 socat[18] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2023-04-09T15:14:17.777743 #1]  INFO -- :
I, [2023-04-09T15:14:17.777978 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2023-04-09T15:14:17.780674 #1]  INFO -- :
I, [2023-04-09T15:14:17.780774 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2023-04-09T15:14:17.783086 #1]  INFO -- :
I, [2023-04-09T15:14:17.783187 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-04-09T15:14:17.785212 #1]  INFO -- :
I, [2023-04-09T15:14:17.785572 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-04-09T15:14:17.787419 #1]  INFO -- :
I, [2023-04-09T15:14:17.792028 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2023-04-09T15:14:17.795856 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2023-04-09T15:14:17.800063 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2023-04-09T15:14:17.803729 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2023-04-09T15:14:17.803973 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2023-04-09T15:14:20.700845 #1]  INFO -- :
I, [2023-04-09T15:14:20.701049 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2023-04-09T15:14:20.702825 #1]  INFO -- :
I, [2023-04-09T15:14:20.702966 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2023-04-09T15:14:20.721467 #1]  INFO -- :
I, [2023-04-09T15:14:20.721608 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2023-04-09T15:14:20.723772 #1]  INFO -- :
I, [2023-04-09T15:14:20.724078 #1]  INFO -- : > /root/upgrade_postgres
I, [2023-04-09T15:14:20.729475 #1]  INFO -- :
I, [2023-04-09T15:14:20.729627 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2023-04-09T15:14:20.731329 #1]  INFO -- :
I, [2023-04-09T15:14:20.732920 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2023-04-09T15:14:20.733526 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2023-04-09T15:14:20.734037 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2023-04-09T15:14:20.734534 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2023-04-09T15:14:20.735044 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2023-04-09T15:14:20.735529 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2023-04-09T15:14:20.735970 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2023-04-09T15:14:20.740651 #1]  INFO -- :
I, [2023-04-09T15:14:20.741067 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2023-04-09T15:14:20.741412 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2023-04-09T15:14:20.742000 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2023-04-09T15:14:20.742832 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2023-04-09T15:14:20.743206 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-04-09T15:14:20.743634 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-04-09T15:14:20.744069 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2023-04-09T15:14:20.745220 #1]  INFO -- : > sleep 5
2023-04-09 15:14:20.905 UTC [41] LOG:  starting PostgreSQL 13.10 (Debian 13.10-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2023-04-09 15:14:20.905 UTC [41] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2023-04-09 15:14:20.906 UTC [41] LOG:  listening on IPv6 address "::", port 5432
2023-04-09 15:14:20.910 UTC [41] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-04-09 15:14:20.917 UTC [44] LOG:  database system was shut down at 2023-04-09 15:14:06 UTC
2023-04-09 15:14:20.938 UTC [41] LOG:  database system is ready to accept connections
I, [2023-04-09T15:14:25.748877 #1]  INFO -- :
I, [2023-04-09T15:14:25.749295 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2023-04-09 15:14:25.870 UTC [54] postgres@postgres ERROR:  database "discourse" already exists
2023-04-09 15:14:25.870 UTC [54] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2023-04-09T15:14:25.872274 #1]  INFO -- :
I, [2023-04-09T15:14:25.872476 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2023-04-09 15:14:25.943 UTC [58] postgres@discourse ERROR:  role "discourse" already exists
2023-04-09 15:14:25.943 UTC [58] postgres@discourse STATEMENT:  create user discourse;
I, [2023-04-09T15:14:25.946885 #1]  INFO -- :
I, [2023-04-09T15:14:25.947058 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2023-04-09T15:14:25.993550 #1]  INFO -- : GRANT
I, [2023-04-09T15:14:25.993813 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2023-04-09T15:14:26.045311 #1]  INFO -- : ALTER SCHEMA
I, [2023-04-09T15:14:26.045719 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2023-04-09T15:14:26.109929 #1]  INFO -- : CREATE EXTENSION
I, [2023-04-09T15:14:26.110387 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2023-04-09T15:14:26.159901 #1]  INFO -- : CREATE EXTENSION
I, [2023-04-09T15:14:26.160347 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2023-04-09T15:14:26.208779 #1]  INFO -- : CREATE EXTENSION
I, [2023-04-09T15:14:26.208956 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2023-04-09T15:14:26.254074 #1]  INFO -- : CREATE EXTENSION
I, [2023-04-09T15:14:26.254400 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2023-04-09T15:14:26.256780 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2023-04-09T15:14:26.338125 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2023-04-09T15:14:26.343406 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2023-04-09T15:14:26.343640 #1]  INFO -- : > echo postgres installed!
I, [2023-04-09T15:14:26.346487 #1]  INFO -- : postgres installed!
I, [2023-04-09T15:14:26.350869 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2023-04-09T15:14:26.355067 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2023-04-09T15:14:26.358918 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2023-04-09T15:14:26.360582 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2023-04-09T15:14:26.361325 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2023-04-09T15:14:26.362334 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2023-04-09T15:14:26.364621 #1]  INFO -- :
I, [2023-04-09T15:14:26.365066 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2023-04-09T15:14:26.365723 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2023-04-09T15:14:26.366633 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2023-04-09T15:14:26.367731 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2023-04-09T15:14:26.368927 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2023-04-09T15:14:26.369973 #1]  INFO -- : > echo redis installed
I, [2023-04-09T15:14:26.371760 #1]  INFO -- : redis installed
I, [2023-04-09T15:14:26.372049 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2023-04-09T15:14:26.378137 #1]  INFO -- : logfile ""
I, [2023-04-09T15:14:26.378305 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-04-09T15:14:26.379515 #1]  INFO -- : > sleep 10
102:C 09 Apr 2023 15:14:26.398 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
102:C 09 Apr 2023 15:14:26.398 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=102, just started
102:C 09 Apr 2023 15:14:26.398 # Configuration loaded
102:M 09 Apr 2023 15:14:26.399 * monotonic clock: POSIX clock_gettime
102:M 09 Apr 2023 15:14:26.401 * Running mode=standalone, port=6379.
102:M 09 Apr 2023 15:14:26.401 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
102:M 09 Apr 2023 15:14:26.401 # Server initialized
102:M 09 Apr 2023 15:14:26.402 * Loading RDB produced by version 7.0.7
102:M 09 Apr 2023 15:14:26.402 * RDB age 20 seconds
102:M 09 Apr 2023 15:14:26.402 * RDB memory usage when created 0.82 Mb
102:M 09 Apr 2023 15:14:26.402 * Done loading RDB, keys loaded: 0, keys expired: 0.
102:M 09 Apr 2023 15:14:26.402 * DB loaded from disk: 0.001 seconds
102:M 09 Apr 2023 15:14:26.402 * Ready to accept connections
I, [2023-04-09T15:14:36.382275 #1]  INFO -- :
I, [2023-04-09T15:14:36.382538 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2023-04-09T15:14:36.386122 #1]  INFO -- : thpoff is installed!
I, [2023-04-09T15:14:36.386354 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2023-04-09T15:14:36.448247 #1]  INFO -- :
I, [2023-04-09T15:14:36.448457 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2023-04-09T15:14:36.512976 #1]  INFO -- :
I, [2023-04-09T15:14:36.513150 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2023-04-09T15:14:36.577994 #1]  INFO -- :
I, [2023-04-09T15:14:36.578227 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2023-04-09T15:14:36.584694 #1]  INFO -- :
I, [2023-04-09T15:14:36.587187 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2023-04-09T15:14:36.591590 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2023-04-09T15:14:36.595502 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2023-04-09T15:14:36.599519 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2023-04-09T15:14:36.603302 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2023-04-09T15:14:36.607130 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2023-04-09T15:14:36.607239 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2023-04-09T15:14:36.607535 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-04-09T15:14:36.609301 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
129:C 09 Apr 2023 15:14:36.615 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
129:C 09 Apr 2023 15:14:36.615 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=129, just started
129:C 09 Apr 2023 15:14:36.616 # Configuration loaded
129:M 09 Apr 2023 15:14:36.616 * monotonic clock: POSIX clock_gettime
129:M 09 Apr 2023 15:14:36.616 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
129:M 09 Apr 2023 15:14:36.616 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (32972/32972), done.
I, [2023-04-09T15:16:49.208465 #1]  INFO -- : HEAD is now at 59e548540 Build(deps): Bump sass from 1.58.3 to 1.59.2 in /app/assets/javascripts (#20656)
I, [2023-04-09T15:16:49.208977 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2023-04-09T15:16:49.382100 #1]  INFO -- :
I, [2023-04-09T15:16:49.382245 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --prune --prune-tags origin tests-passed
  fi
fatal: unable to access 'https://github.com/discourse/discourse.git/': Could not resolve host: github.com
I, [2023-04-09T15:17:29.506241 #1]  INFO -- :
I, [2023-04-09T15:17:29.506599 #1]  INFO -- : Terminating async processes
I, [2023-04-09T15:17:29.506724 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 41
2023-04-09 15:17:29.506 UTC [41] LOG:  received fast shutdown request
I, [2023-04-09T15:17:29.506972 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 102
102:signal-handler (1681053449) Received SIGTERM scheduling shutdown...
2023-04-09 15:17:29.509 UTC [41] LOG:  aborting any active transactions
2023-04-09 15:17:29.511 UTC [41] LOG:  background worker "logical replication launcher" (PID 50) exited with exit code 1
2023-04-09 15:17:29.512 UTC [45] LOG:  shutting down
2023-04-09 15:17:29.546 UTC [41] LOG:  database system is shut down
102:M 09 Apr 2023 15:17:29.591 # User requested shutdown...
102:M 09 Apr 2023 15:17:29.591 * Saving the final RDB snapshot before exiting.
102:M 09 Apr 2023 15:17:29.596 * DB saved on disk
102:M 09 Apr 2023 15:17:29.596 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  else
  fi
' failed with return #<Process::Status: pid 144 exit 128>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"code", "cmd"=>["sudo -H -E -u discourse git reset --hard", "sudo -H -E -u discourse git clean -f", "sudo -H -E -u discourse bash -c '\n  if [ $(git rev-parse --is-shallow-repository) == \"true\" ]; then\n      git remote set-branches --add origin main\n      git remote set-branches origin $version\n      git fetch --depth 1 origin $version\n  else\n      git fetch --prune --prune-tags origin $version\n  fi\n'", "sudo -H -E -u discourse bash -c '\n  if [[ $(git symbolic-ref --short HEAD) == $version ]] ; then\n      git pull\n  else\n      git -c advice.detachedHead=false checkout $version\n  fi\n'", "mkdir -p tmp", "chown discourse:www-data tmp", "mkdir -p tmp/pids", "mkdir -p tmp/sockets", "touch tmp/.gitkeep", "mkdir -p                    /shared/log/rails", "bash -c \"touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log\"", "bash -c \"ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log $home/log\"", "bash -c \"mkdir -p           /shared/{uploads,backups}\"", "bash -c \"ln    -s           /shared/{uploads,backups} $home/public\"", "bash -c \"mkdir -p           /shared/tmp/{backups,restores}\"", "bash -c \"ln    -s           /shared/tmp/{backups,restores} $home/tmp\"", "chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp", "[ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete"]}
bootstrap failed with exit code 128
4a1c0166ec59d1b6a4cc0fc19b6a03ebdd78386d5e4bb5f7f5cc3ea3f905f4d7
Questo è solo un avviso, questo è il problema:
Devi risolvere il problema del perché GitHub non è accessibile dal server.
Posso clonare manualmente sul server, non capisco perché la configurazione non clona?
git clone https://github.com/discourse/discourse.git
Clonazione in 'discourse'...
remote: Enumerating objects: 651082, done.
remote: Counting objects: 100% (504/504), done.
remote: Compressing objects: 100% (323/323), done.
remote: Total 651082 (delta 242), reused 412 (delta 178), pack-reused 650578
Receiving objects: 100% (651082/651082), 556.51 MiB | 41.56 MiB/s, done.
Resolving deltas: 100% (425147/425147), done.
Updating files: 100% (33083/33083), done.
Forse l’MTU nel container Docker? Vedi
