Hi
I am new to discourse and setting it up to be used as a school discussion board. I would like that once a question is asked, there is a section where students can collaborate on solutions.
Something like in the picture below
I would like any suggestions on how to approach this.
Thank you
schungx
(Stephen Chung)
1 november 2017 om 02:53
Question.
Then a blank answer post, change to Wiki.
Students can edit the Wiki to modify the answer.
They can also post comments.
When solved, use the solved plugin to mark the Wiki as the solution to the question.
Do you think this could be automated?
schungx
(Stephen Chung)
1 november 2017 om 04:33
4
Probably not without a specialized plugin
pfaffman
(Jay Pfaffman)
1 november 2017 om 08:30
5
I believe that you can configure a category to automatically make the first post a wiki.
schungx
(Stephen Chung)
1 november 2017 om 08:54
6
Probably needs the SECOND post to be a Wiki…
pfaffman
(Jay Pfaffman)
1 november 2017 om 12:42
7
I don’t think it’s be that bad if the first post contained the question and the answer.
There’s been discussion about making second post a wiki. Not a bad idea.
I have a new discourse install and would like to modify the Wiki functionality. I’ve got a good grasp on creating wikis, having the first post automatically be a wiki, etc. What I’d love is to have the second post automatically be a wiki, and the first one not.
I don’t think the functionality exists, but maybe I can get half way there. Can I configure the software to automatically create a second post whenever a new user posts? Then, a moderator can step in an simply flick the Wiki switch for t…
Thanks everyone. I think I will go with the plugin approach
