مغير حجم صورة Composer لم يعد يشير بصريًا إلى الحجم الحالي (%)
I’m certain that the currently selected size for an upload used to be in black, bold and un-clickable text. I noticed this last week, is this the side-effect of another change?
11111
4 إعجابات
@Johani is part way through experimenting with a new component that should address this and a lot more.
I guess the highlight missing is a result of the refactor @Roman did?
5 إعجابات
I haven’t merged the refactor yet, I’m planning on doing it tomorrow morning.
6 إعجابات
Merging the refactor fixed the issue. :+1:
7 إعجابات
Thanks :raised_hands:
One minor issue, when you upload an image, the default of 100% isn’t pre-selected and in black, bold text. Once you click it, it becomes fine. Can we have it selected automatically so that it behaves just like before?
Try and resize this image to see that in the composer:
6 إعجابات
I pushed a fix yesterday. This is the default behavior now. :+1:
7 إعجابات
