Configure OneLogin's SAML for Discourse
Here’s how to configure Discourse to allow login and registration with OneLogin’s SAML.
Configure OneLogin
Create OneLogin account
Go to OneLogin and create an account.
Create new app: SAML Test Connector (IdP w/attr)
From your dashboard create new app.
Search for SAML Test Connector (IdP w/attr)
Configure app
Let’s assume that the URL of our Discourse instance is http://discourse.example.com. Let’s configure it.
Switch to Configuration tab and fill out these details:
  • Audience: http://discourse.example.com
  • Recipient: http://discourse.example.com/auth/saml/callback
  • ACS (Consumer) URL Validator: ^http:\/\/discourse\.example\.com\/auth\/saml\/callback\/$
  • ACS (Consumer) URL: http://discourse.example.com/auth/saml/callback
Copy certificate info and SAML 2.0 Endpoint
Switch to SSO tab.
Click on View Details link under certificate and copy SHA fingerprint and X.509 Certificate. Note them down, it will be used when configuring Discourse app.
Copy and note SAML 2.0 Endpoint (HTTP) URL.
Configure Discourse
Install discourse-saml plugin
Follow this guide to install discourse-saml plugin.
Configure discourse-saml plugin
Edit app.yml
cd /var/discourse
vim containers/app.yml
and add these variables under env section:
DISCOURSE_SAML_TITLE: "Example SAML"
DISCOURSE_SAML_TARGET_URL: {SAML 2.0 Endpoint URL}
DISCOURSE_SAML_LOG_AUTH: "true"
DISCOURSE_SAML_CERT_FINGERPRINT: {SHA fingerprint}
DISCOURSE_SAML_CERT: {X.509 Certificate without line breaks}
  • replace {SAML 2.0 Endpoint URL} with SAML 2.0 Endpoint URL copied from OneLogin SSO tab
  • replace {SHA fingerprint} with SHA fingerprint copied from OneLogin SSO tab → Certificate section
  • replace {X.509 Certificate without line breaks} with X.509 Certificate copied from OneLogin SSO tab → Certificate section, note that there must be no line breaks and remove begin and end marker
Rebuild app
For changes to take effect rebuild app
cd /var/discourse
./launcher rebuild app
Voila! :tada:
You should be able to login now using OneLogin’s SAML.
