The user stormfinger is troubleshooting SAML login issues in Discourse after reinstalling it in Docker. Initially, they were redirected to a blank page after SAML authentication, but found logs via the admin interface. They encountered errors related to certificate validation, particularly an OpenSSL::X509::CertificateError when validating the SAML response. pfaffman suggested checking logs through the admin panel. stormfinger realized the SAML plugin required a certificate, which was previously not needed, and confirmed that the issue stemmed from certificate configuration. After adding the certificate and its public part to the SAML plugin, they resolved the problem stormfinger.
hi
ive got two problems…
previous lad made SAML possible now i reinstalled discourse that is in docker and i got saml plugin running and im welcomed to login screen but after login on saml im redirected to blank
“correct domain”/auth/saml/callback and it seems i even cant find where are logs
hi
i found logs in /logs URL but /u/user got me there. i dont know what is missing in settings that LDAP user cannot neither register nor login… i tried both but i get empty page..here is log …in settings i didnt provide fields that should match it says itll will be automatic would that be cousing a problem? password and user are correct i tried directly loging in LDAP.. below are logs traces
SAML was previously working when site wasnt build in docker so i guess ..i need to set up additional settings in SAML but i cant find documentation on how to proceed
i didnt proprerly configure SAML plugin to use PUT method as i saw now in their github… now i dont send certificate for discourse from our SAML site. is that a must? previously it was working without certificate. is discord SAML proper plugin to login users from remote simpleSAMLphp?
i specificaly added certificat to saml response and put public part into SAML plugin. the public part i created with openssl and now i get error certificate error.. i think main problem here is dealing with certificates.. but im unsure how to proceed ..any help would be very welcome.
