nahimov
September 24, 2020, 7:56am
1
Hello @david !
Are there any changes since this topic?
Here’s how to configure Discourse to allow login and registration with OneLogin’s SAML.
Configure OneLogin
Create OneLogin account
Go to OneLogin and create an account.
Create new app: SAML Test Connector (IdP w/attr)
From your dashboard create new app.
[image]
Search for SAML Test Connector (IdP w/attr)
[image]
Configure app
Let’s assume that the URL of our Discourse instance is http://discourse.example.com. Let’s configure it.
Switch to Configuration tab and fill out these details…
I am interested in this:
With OAuth2 Basic Plugin have one BIG problem - if the user is new to Discourse, then, after authentication, a window appears with the data of the new user.
The SAML plugin has an option DISCOURSE_SAML_AUTO_CREATE_ACCOUNT.
But what about OAuth2 plugin?
david
(David Taylor)
September 24, 2020, 8:27am
Yes you can use this new setting:
I just added some new site settings which will help with this. To skip the ‘create new account’ screen, enable sso_overrides_username, sso_overrides_email and sso_overrides_name.
Then to skip the popup completely, enable external_auth_skip_create_confirm
If you don’t see that option, make sure you’re on the latest version of tests-passed.
nahimov
September 24, 2020, 8:34am
3
Great! Thanks.
Is there any guides how to integrate Keycloak and Discourse OAuth2 plugin? Or other IDP…
david
(David Taylor)
September 24, 2020, 8:39am
4
I would suggest starting with
Summary
Discourse OpenID Connect allows an OpenID Connect provider to be used as an authentication provider for Discourse.
Install Guide
This plugin is bundled with Discourse core. There is no need to install the plugin separately.
Features
The plugin aims to provide a minimal implementation of the specification . Specifically, it supports the “Authorization Code Flow”. To get started, follow the plugin installation instructions , or contact your hosti…
And finding the openid discovery document URL using these instructions
