Connection Reset By Peer
In a support thread titled “Connection Reset By Peer,” JBPrime reported an issue while setting up a fresh Discourse instance on Digital Ocean: the admin account creation email never sent, despite successful telnet tests. The discourse-doctor mail test failed with “Connection reset by peer” when using SMTP port 465 with Hover’s mail server. itsbhanusharma suggested trying port 587 instead, noting that 465 may require additional configuration. JBPrime confirmed that switching to port 587 resolved the issue. The original error was flagged as uncommon, with no built-in solution, and users were encouraged to report such errors to meta.discourse.org if no fix is found.
Installed a fresh copy in a Digital Ocean droplet, everything goes through fine until creating an admin account which never gets sent. I’ve looked through the troubleshooting topic and tried several option, even the telnet goes through no problem. When performing the doctor checkup I receive the following
Blockquote
==================== MAIL TEST ====================
For a robust test, get an address from http://www.mail-tester.com/
Or just send a test message to yourself.
Email address for mail test? (‘n’ to skip) [office@indiebasement.live]: 2tonwaffle@thecollective.network
Sending mail to 2tonwaffle@thecollective.network. . .
Testing sending to 2tonwaffle@thecollective.network using mail.hover.com:465, username:office@indiebasement.live with plain auth.
======================================== ERROR ========================================
UNEXPECTED ERROR
====================================== SOLUTION =======================================
This is not a common error. No recommended solution exists!
Please report the exact error message above to https://meta.discourse.org/
(And a solution, if you find one!)
Replacing: SMTP_PASSWORD
Replacing: LETSENCRYPT_ACCOUNT_EMAIL
Replacing: DEVELOPER_EMAILS
Replacing: DISCOURSE_DB_PASSWORD
Replacing: Sending mail to
==================== DONE! ====================
I check the email which I have through Hover and I’m able to send and receive email fine when testing to another email address.
Have you tried a different port (e.g. 587)
465 needs additional configuration depending upon how the SMTPS server is set up.
Changing to that port (587) did the trick, thank you.
