That wasn’t exactly the question. Yesterday the launcher command started refusing to work without --ignore-prereqs. But I’m using the default docker setup for redhat/centos. The ones you suggest are not available on my platform according to the docker site. So I wondered if the command line started demanding --ignore-prereqs, will the web updater fail now because you don’t have a way to “ignore” there.
mntbighker
(Mark Moorcroft)
21
Temas relacionados
| Tema | Respuestas | Vistas | Actividad | |
| Container fails to (re)start after system update | 7 | 2182 | 10 Junio 2016 | |
| Can't run ./launcher rebuild app - Docker storage driver is unsupported | 71 | 13742 | 26 Agosto 2019 | |
| Your Docker installation is not working correctly after running launcher rebuild app | 6 | 1515 | 16 Febrero 2019 | |
| Device 'docker0' missing after system upgrade? | 26 | 5435 | 22 Diciembre 2016 | |
| New installation on Fedora 23 - FAILED RuntimeError: cd /var/www/discourse && su discourse -c | 17 | 2754 | 21 Marzo 2016 |
