When you make a PM into a topic the
icon seems to be missing as you can see in the image below.
This is in the topic
admin actions in a PM
The discussion addresses an issue where the
icon is missing when converting a private message (PM) to a topic in the admin actions. ondrej first reported the missing icon, and Lilly noted it’s present but not displayed due to potential FontAwesome 6 issues. awesomerobot found that the icon appears correctly in some cases, suggesting a code-level inconsistency. Moin clarified that the issue stems from a missing icon definition for “open_topic” in the code, unlike “public_topic,” and pointed to the relevant GitHub files. awesomerobot confirmed the fix is coming via a PR.
oh it’s there all right, it’s just not showing because of some shenanigans, possibly fontawesome 6 not being awseome…
lol
Thanks for the heads up!
I just converted this to a PM and back to a topic and it seems the icon appears correctly? ![]()
it looks like this is expecting a different icon for some reason…
edit: looking at the code for small actions, it appears it falls back to “exclamation” when a matching icon can’t be found… but the public_topic does have an icon defined… the plot thickens
I’m not sure that’s ever worked on our forum, we have many silly posts that were made into actions as a joke, and none of those have icons visible.
That happens because Meta is a public site. The action code is different in that case.
There is different text when login required is enabled.
I think the problem is that while there is an icon for “public_topic”, there is no icon defined for “open_topic”.
Ah that explains it! thanks for figuring that out
This PR will add the icon:
