Copying a code block does not include leading spaces
The discussion highlights a bug where using the copy button on a code block fails to preserve leading spaces. supermathie reports that on Chromium Linux, copying content from both posts and chat strips indentation, providing a test case showing the discrepancy between the visual block and the copied text. sam notes that this is a long-standing issue, tracing the bug back to the original implementation of the copy button by @justin in 2020.
Using the copy button[1] to copy a code block does not include any leading spaces.
Test case:
        GPU0    GPU1    NIC0    NIC1    CPU Affinity    NUMA Affinity   GPU NUMA ID
GPU0    X       NV12    NODE    NODE    0-15            0               N/A
GPU1    NV12    X       PHB     PHB     0-15            0               N/A
NIC0    NODE    PHB     X       PIX
NIC1    NODE    PHB     PIX     X
What is actually copied:
NIC0    NODE    PHB     X       PIX
NIC1    NODE    PHB     PIX     X
Same thing happens in both posts and chat.
Chromium on Linux.
  1. ↩︎
This bug is ancient, it tracks all the way back to the original implementation of the button by @justin in 2020
