Could the undelete flow be improved?
The discussion revolves around improving the undelete flow on the platform. gmanjapan highlights a usability issue: users often delete a post to correct an error but then face a gap in the workflow when they want to edit it, as undeleting and editing are separate actions. This delay allows others to respond to the incorrect version, potentially derailing discussions. They suggest that allowing users to edit a deleted post directly—effectively making the submit button act as an undelete—would streamline the process. codinghorror questions the need to delete posts at all, arguing that editing is usually sufficient and noting the 5-minute grace period for edits. The core debate centers on whether the current workflow encourages confusion or if better integration between editing and undeleting could improve user experience.
Here’s the flow right now as far as I can tell
  1. Type reply
  2. Post it
  3. Realize something is wrong
  4. Delete it so no one responds to the wrong message
  5. Now you want to fix it but there’s no way to pick edit and undelete
Instead you have to pick undelete as a separate action which means people start immediately responding to the message you were trying to fix while you take 5 to 10 minutes to edit the message.
That seems like just being able to pick edit on a deleted message and having the the submit/reply button be effectively undelete would lead to better discussions.
I suppose someone will tell me users should just make a new reply but I wouldn’t expect the average user to guess that workflow. I’d expect them to undelete and edit which seems to lead to derailed discussions.
Why not just edit the post? Why do you have to delete it? I am having a hard time following what I would post that is so traumatically wrong that I must delete it instead of simply editing it.
There is also a 5 minute default grace period on all edits, of course.
3 „Gefällt mir“
