Custom emoji selection seems broken, need advice
Unless this is a plugin issue, it seems not to be though. The custom emoji selection falls off the bottom of the selector, like so
See the custom bread emoji falling off the selector.
Also I really, really, really, really, really want a way to restrict emojis selection to certain emojis, but can find no working way of doing so, even with a plugin. Does anyone know of any existing method to do so that works?
Thx!
See
Which emoji set are you using?
Thx for link, will try it out. It’s just whatever emoji set comes default, with custom emojis uploaded in the admin section. Going to try to eliminate everything except the custom emojis.
Ok so it worked with that theme. There is an annoying “custom emojis” header still there that all users can see, but maybe I can hide it with CSS in my free time.
Small update on this - we now have the emoji deny list admin setting which allows you to control which emojis can be used on your forum:
