Unfortunately, I am now dealing with simultaneous endpoints being called that update the user custom_fields at the same time, making the values set by me as :text to turn into arrays.
Note that when two transaction run concurrently in two threads, each thread doesn’t see the other transaction’s changes until they are committed successfully. It does however see its own changes (this is a dumbed-down explanation, reality is much more complicated).
Unfortunately I am now faced with updating sensitive data potentially at the same time. I think this happens because I am doing it via endpoints, but this is the only way I can do it and I do no have control over the calls. It can be 1 call, it can be 10.
I can try to minimize the calls from the app and bulk send some data, the problem is there are 2 sources for the calls: mobile and external services.
