fzngagan
(Faizaan Gagan)
1
@eviltrout
Repro steps:
- Let’s create a user field and it has id
1.
- Run the second line of the below code twice.
Case 1
up = UserUpdater.new(Discourse.system_user, User.find(1))
up.update({:custom_fields=>{:user_field_1=>"abc"}})
- You’ll see
abc twice when you go to /my/preferences/profile
Surprisingly, when the profile is updated via /my/preferences/profile, it does so perfectly fine.
Case 2
This seems to work fine
params = ActionController::Parameters.new({:custom_fields=>{:user_field_1=>"abc"}})
up.update(params.permit!)
What happens is, in Case 1, the value is pushed to an array and is displayed as comma-separated values on /my/preferences/profile.
Case 2 seems to do the correct thing i.e. it replaces the current value with the new one but wrapping it in ActionController::Parameters is unnatural.
eviltrout
(Robin Ward)
3
This does seem like a valid bug and should be fixed, thanks for reporting it!
fzngagan
(Faizaan Gagan)
5
My analysis comes down to this.
# case 1
u1 = User.find(1)
u1.custom_fields[:user_field_1] = "abc"
u1.save
# case 2
u1.custom_fields["user_field_1"] = "abc"
u1.save
In case 1, A new UserCustomField is created per call to u1.save
In case 2, All UserCustomField with the name ‘user_field_1’ are deleted from the db
except the specified.
All and all the symbol and string versions of the same key are treated differently in the HasCustomFields mixin.
fzngagan
(Faizaan Gagan)
6
Ok, I went for it. Here’s the PR which fixes the issue
fzngagan
(Faizaan Gagan)
7
Ok, so this one is merged.
