Custom post types failing to update associated Discourse posts
@angus, it’s possible another PR is in order. We’re experiencing Discourse publishing errors when updating our WordPress events with WordPress v5.9.1 and the WP-Discourse plugin v2.4.0.
I recorded a quick video so you can recreate the issue on your end.
Here’s the automated email from WordPress about the Discourse publishing failure:
[The Puttyverse] Discourse Publishing Failure
A post has failed to publish on Discourse from your site [The Puttyverse].
The post 'Music Accountability Huddle - March 30, 2022 (4:15 pm UTC)' was published on WordPress
by [Username Removed for Privacy], on 2022-02-23 20:35:36.
<https://theputtyverse.com/events/music-accountability-huddle-march-30-2022/>
Reason for failure:
A 400 response code was returned from Discourse.
param is missing or the value is empty: post
Did you mean?  post
               post[raw]
               controller
               title
1 лайк
Thanks for the detailed video @JoelZaslofsky. This is a different issue from the one being discussed in that other topic, so I’ve moved it to a new topic. I’ll take a look at it in depth tomorrow.
1 лайк
@JoelZaslofsky This will be fixed when this is merged.
*update: merged. 2.4.1 is now live.
2 лайка
Angus, I think there’s a good chance this is what was affected us as well. I’ll wait a bit to see if things are stable with 2.4.1 and push it out over the next few days to confirm.
1 лайк
It’s true. I just tested with version 2.4.1 and the original issue I documented in this forum thread is fixed. Thanks Angus!
2 лайка
