Custom theme component doesn't show on first render
The user th21 reports that a custom theme component, which displays a clickable banner for logged-in users, fails to render on the first page load after upgrading to Discourse 2.9.0.beta5. The component only appears after refreshing the page multiple times and disappears when opening the site in a new tab or window. Initially, the component was placed in the <body> tag using a script tag with data-template-name, but moving it to the <head> tag resolved the issue. th21 notes that this worked fine before the upgrade, suggesting the problem may be related to the update.
I created a simple component that will display a simple clickable banner for the login users. It works fine until I upgrade to 2.9.0.beta5: Security Fixes, Block Hotlinked Media, PM Tagging, Search Improvements, and more
The component only shows up when I refresh the page 2~3 times and it will disappear every time when I open my site in a new tab/window. I see the same issue happens on theme-creator.
Any idea why this happens? Following is the code I use.
const h = require("virtual-dom").h;
let user = api.getCurrentUser();
if(user){
 api.createWidget("fixed-banner", {
     tagName: "div.container-row",
     html() {
         return h('div.content', [
             h('a.bannerLink', {
                href: '/categories',
             }, 'test'),
</script>
Find why, I used to put
<script type="text/x-handlebars" data-template-name="/connectors/above-site-header/theme-component">
    {{mount-widget widget="theme-component"}}
</script>
in <body> tag, moving to head tag fixed this issue. But it’s weird that the issue suddenly happen after recent upgrade, it used to work fine.
