התאמה אישית של התעודה ש-discobot מעניק
Any idea what logo the Certificate of Achievement pulls from to generate or if we can upload one specifically for that?
Are you referring to the certificate that you get at the end of the discobot tutorial?
Yes. Or is there a way to change the colors of the certificate itself? Or change what logo is displayed on the certificate? (We just want it to match - and what its pulling out of the box isn’t ideal)
The certificate uses the site logo that you set up for your site in the setup wizard. If you wish to use a different one, change it via the /wizard. I don’t think it’s easy to change up the certificate but you could change that logo.
What is the wizard? The initial setup?
Basically we’d like it to pull the main logo we set up…but it’s pulling another one. Not the very first “main” one in the branding section that has all the different uploaded logos.
I believe the logo that it pulls is the square logo that you set at /wizard/steps/branding
Ok, guess it won’t work. Square logo is light. Thanks.
