A discussion about adding custom email headers or subject tags to automatically sort notification emails sent by Discourse. XioNoX suggests using custom headers similar to Bugzilla’s notification emails.
downey points out a related discussion on showing categories in email notifications. downey also mentions that a category-specific List-Id header is now available, and users can add custom headers using the email custom headers site setting.
llc1990 provides instructions on how to set custom email headers. However, mattdm and mattdm discover that formatting using %{optional_pm}%{optional_cat}%{topic_title} does not work in custom headers.
simon investigates the code and finds that the custom headers setting does not support template substitution. mattdm suggests that using the same templating as the email subject setting could make custom headers more useful.
To be able to sort automatically notification emails sent by Discourse, it would be great if they could have customs headers (or a subject tag) based on the message’s content/content:
For example, here is a list of headers Bugzilla sends with each notification email:
X-Bugzilla-Reason: CC AssignedTo
X-Bugzilla-Type: dep_changed
X-Bugzilla-Watch-Reason: None
X-Bugzilla-Classification: Other
X-Bugzilla-ID: 1014331
X-Bugzilla-Product: mozilla.org
X-Bugzilla-Component: Server Operations
X-Bugzilla-Version: other
X-Bugzilla-Keywords:
X-Bugzilla-Severity: normal
X-Bugzilla-Who: foobar@email.com
X-Bugzilla-Status: RESOLVED
X-Bugzilla-Resolution: FIXED
X-Bugzilla-Priority: –
X-Bugzilla-Assigned-To: email@email.com
X-Bugzilla-Target-Milestone: —
X-Bugzilla-Flags:
X-Bugzilla-OS: Linux
X-Bugzilla-Changed-Fields: Status Resolution
X-Bugzilla-Changed-Field-Names: bug_status resolution
FYI, there is now a category-specific List-Id header sent along with unsubscribe headers, and the ability to add your own generic headers for all notifications with the email custom headers site setting.
템플릿과 email_subject 설정 사이의 관계에 대해 완전히 이해하지 못하는 부분이 있습니다. 템플릿이 존재하는 경우 email_subject가 사용되지 않는 것처럼 보이지만, 템플릿이 없는 경우가 언제인지 정확히 알지 못합니다. 이 부분을 제외하면, 커스텀 헤더를 생성하는 함수가 동일한 템플릿 처리 방식을 사용한다면 이 방식이 작동할 것이며, 커스텀 헤더에 유용한 동적 정보를 포함할 수 있을 것입니다.
