Unfortunately there is not an easy way to import bits and pieces of a theme. You will have to cherry pick the styles for the components/features you like from the compiled CSS or Sass and apply theme on top of the theme you are currently using.
Hi @trangchongcheng, thanks for the feedback, this has been fixed by the latest update.
Thank…i working…
But when i set google adsense (ads auto responsive) then forum cant responsive on mobile.
Thank you very much for this theme !
I have some problem with the first button:
Also the tekst below the title is not displayed ?
I have also an exclamation mark next ot the name
is this theme still being updated ? I already figured out the exclamation mark
ok, almost there…
The categorie button is not in Material Design, how can i fix this ?
Hi @notriddle, the badges section is now cleaned up in the latest version.
Hi @PatrickH,
Regarding category dropdown, it works both for us at https://labs.daemon.com.au/ and on Discourse Theme Creator.
The reason I can think of at this stage is maybe you have an older version of Discourse and the markup for the category button is somehow different.
I have version: Discourse 1.9.5
That’s the topic preview plugin…
@modius I just submitted three PRs for minor fixes to this theme. Let me know if the descriptions of what is being fixed are not clear:
@sesemaya see post above. ![]()
@sesemaya Thanks for merging! In the course of the modifications and other updates we seem to have ended up with two toggles in the mobile compose. I think it might be because you’ve added both .toggle-toolbar and fa-bars to the material icon :before overrides.
This is likely because I just merged FontAwesome 5 into master and now the core icons are no longer in :befores (more here). I tried removing the :before on the browser console, and it seems to do the trick.
@sesemaya is taking a look at what we can do to preserve Material icons in light of the FontAwesome changes tomorrow.
@modius, at the moment it looks like using the old icon render works. Here’s the code if you want to try it out in the </head> section of a theme component:
const h = require("virtual-dom").h;
// Support for font awesome icons
function faClasses(icon, params) {
let classNames = `fa fa-${icon.replacementId || icon.id} d-icon d-icon-${
icon.id
if (params) {
if (params.modifier) {
classNames += " fa-" + params.modifier;
if (params["class"]) {
classNames += " " + params["class"];
return classNames;
// default resolver is font awesome
api.registerIconRenderer({
string(icon, params) {
let tagName = params.tagName || "i";
let html = `<${tagName} class='${faClasses(icon, params)}'`;
if (params.title) {
html += ` title='${I18n.t(params.title).replace(/'/g, "'")}'`;
if (params.label) {
html += " aria-hidden='true'";
html += `></${tagName}>`;
if (params.label) {
html += `<span class='sr-only'>${params.label}</span>`;
return html;
node(icon, params) {
const properties = {
className: faClasses(icon, params),
attributes: { "aria-hidden": true }
if (params.title) {
properties.attributes.title = params.title;
if (params.label) {
return h(tagName, properties, h("span.sr-only", I18n.t(params.label)));
} else {
return h(tagName, properties);
</script>
It looks like there still might be a few icons that aren’t rendering correctly (.fa-thumbtack is the notable one), but in any case, I think this might be one angle to look at.
For those who still wants this modification and bring back + icon, @angus made this one for me.
Thank you @modius and @sesemaya for such incredible theme. ![]()
@tshenry you’re an angel. ![]()
Thanks @tshenry, that did the trick.
Although there are still a few icons that are not rendering correctly, they are because of naming changes in FontAwesome 5. For example, .fa-thumbtack in 5 was .fa-thumb-tack in 4. I will go through the changes and update theme CSS accordingly.
Thanks again for the workaround.
