Daemonite Material Theme
I don’t use the theme, but my guess is:
button.create .d-icon {
    color: #000;
If it mess with other buttons, use this line instead
#topic-footer-buttons button.create .d-icon {
    color: #000;
2 лайка
Thank you very much. The first one has sovled one button problem.
Inside the thread I see now a black icon.
But on the main page “Categories” view I see still the grey “+” on the button:
This theme looks very nice and one of the best among all themes available for Discourse.
I saw it running on labs.daemon.com.au but the mobile experience is not that refined yet. Is that website using the theme with the latest updates?
1 лайк
Your theme is absolutely beautiful and I’m currently using it. I also have the branded header theme component installed and I noticed that when I use your theme, my branded font awesome icons no longer appear. Whereas with my old theme, it will show those icons. It’s not displaying anything (not even the box) but is still clickable. Would you happen to know of some conflicting code that could be causing this to happen?
1 лайк
I just ran into another issue and I don’t know if it’s my specific customization, but I cannot delete images. I can upload them, but once I do, the buttons lose all functionality and I cannot delete or add a new photo. What am I doing wrong? Thanks!
Hi there,
we just wanted to let you know that we are currently experiencing rendering woes like
on our installation at https://meta.ip-tools.org/. As far as we know, we did not make any changes to the system, so the problem appears out of the blue for us.
Most probably it is due to “The connection used to fetch this resources was not secure” errors when trying to load the glyphs from Google Fonts:
We just wanted to leave a note about the issue and will follow up with an attempt to mitigate it by upgrading to the most recent software releases of all components.
With kind regards,
Andreas.
Apologies, reporting the last one was totally our fault. After bootstrapping a new workstation, we activated a bogus firewall setting which denied access to googleapis.com - no wonder these requests would fail. Sorry for the noise!
Nevertheless, it was a good chance to update the theme and receive the numerous updates @sesemaya pushed since end of January (Comparing 83a7de732a13ac9f8bde60aaefbee39269c601fd...89f9f1347fb5755fdbab83f8350ebabe9d532857 · Daemonite/discourse-material-theme · GitHub). As far as we can see everything works fine, so thanks again for the awesome work you are putting into this, Maya!
1 лайк
I have this strange situation where the edit option is not shown in the interface. It’s there, if you hover over it the name appears and you are able to use it if you hit the right spot.
I have this user that keeps accidentally removing posts this way, which is quite unfortunate.
This is viewing a post in Material Design for Discourse and below the same in graceful:
Dear @Not-The-Foggiest,
we have been able to work around this issue as outlined at Some icons are not translated properly · Issue #17 · Daemonite/discourse-material-theme · GitHub the other day by adding this snippet at the appropriate place, effectively disabling the “alt-” variants of the icons to get them visible again:
// Fix MBT#17: Translate "-alt" icons to non-"-alt" ones to
// counter disappearing "edit"- and "delete"-post icons.
// https://github.com/Daemonite/discourse-material-theme/issues/17#issuecomment-479716834
classNames = classNames.replace('-alt', '');
It’s really just a quick workaround but might well help you along.
With kind regards,
Andreas.
4 лайка
У карточек пользователей на десктопе
и
страниц пользователей на мобильных устройствах
сломаны стили CSS. Отступы между полями 0 пикселей и т.д…
Также было бы здорово увеличить аватары на страницах пользователей в мобильной версии.
Так и должны аватары быть такими маленькими на карточках пользователей в десктопной версии?
Очень хочу исправить эти проблемы, так как эта тема теперь моя основная по умолчанию, и она выглядит намного лучше всех остальных тем, включая те, что я делал сам.
Большинство аватаров не отображаются в разделе ответов к сообщениям. Есть какие-либо идеи? Мне очень нравится эта тема. Это также происходит и на вашем сайте. Посмотрите, как аватар Abdulmalik_Hamid не отображается в разделе «2 ответа» к первому сообщению athmangud?
ну, последний коммит был в мае. Аватары на их сайте тоже сломаны, да и мобильная версия — полный хаос. В остальном тема отличная.
Я не вижу никаких сломанных аватаров ни на странице, на которую вы ссылаетесь, ни на других страницах сайта. Не могли бы вы прислать скриншот проблемы, с которой вы столкнулись?
P.S. Мы немного были заняты в последнее время, но мы знаем, что тему пора обновить.
3 лайка
Отсутствуют аватары после нажатия на выпадающий список «x Replies», как здесь, на одной из ваших страниц.
Версия для настольных компьютеров, последний Chrome.
Смотрите красную стрелку. Это гораздо более заметно на более активных форумах, использующих вашу тему. Но проблема присутствует и на странице, с которой был сделан этот скриншот.
1 лайк
Также у карточек пользователей возникают проблемы с отступами в 0 пикселей для имен определенной длины (см. скриншот ниже, где окно сообщения сливается с именем).
Вот пример для рабочего стола, но на мобильных устройствах это проявляется гораздо сильнее: почти все поля в карточках пользователей на мобильных имеют проблемы с отступами. На страницах пользователей на мобильных устройствах тоже много проблем с отступами в 0 пикселей.
У меня сейчас нет возможности сделать скриншот с мобильного устройства, но, полагаю, вы сможете увидеть это на своей стороне.
1 лайк
Верно! Упустил раскрывающийся список Ответы X.
Принято к сведению. Мы запланировали работу по обновлению темы в ближайшие несколько недель. Надеемся, что успеем к Рождеству :slight_smile:
6 лайков
Есть какие-то обновления? Было бы здорово, если бы исправили только этот аватар. Мой форум кажется сломанным из-за этой ошибки.
Я заплачу вам 5 долларов через PayPal, чтобы исправить аватарки в выпадающем меню «Ответы», если вы больше не планируете это делать. Это единственное, что нужно исправить на моем форуме. Я сам обновил тему для своего форума, но не смог разобраться с этим моментом.
Спасибо :slight_smile:
Ещё один момент: пользователи не могут изменить изображения карточки профиля или её фон после первой загрузки.
Это ещё одна очень серьёзная проблема в этой теме.
Но только в этой теме.
У нас очень активный форум, и я не знаю, как это исправить.
Загрузка изображений в разделе «Профиль» также обычно занимает много времени: процесс зависает на некоторое время на отметке 100%, тогда как в других темах такого почти не происходит.
Спасибо.
