按指定时间范围统计用户每日、每周或总数据
-- 覆盖范围:'week'(周)、'all'(全部)或 'date'(日期)
-- [参数]
-- date :start_date = 2019-08-27
-- date :end_date = 2019-09-30
-- text :coverage = week
WITH date_range AS (
SELECT date_trunc('day', dd):: date AS "date", EXTRACT(week from date_trunc('day', dd):: date) AS "week"
FROM generate_series
        ( :start_date::timestamp
        , :end_date::timestamp
        , '1 day'::interval) dd
), likes_given AS (
SELECT u.id, dr.date, dr.week, count(pa.*) AS "likes"
FROM date_range dr
FULL JOIN users u ON (1=1)
LEFT JOIN post_actions pa ON (pa.created_at:: date = dr.date and post_action_type_id=2 AND user_id = u.id)
GROUP BY dr.date, dr.week, u.id
ORDER BY u.id, dr.date
), posts_summary AS (SELECT u.id, u.username, u.created_at, dr.*, count(p.id) - count(t.id) AS replies, count(t.id) AS topics, COALESCE(sum(p.like_count),0) AS likes_received
from date_range dr
FULL OUTER JOIN users u ON (1=1)
LEFT JOIN posts p ON (p.user_id = u.id AND p.created_at::date=dr.date AND p.deleted_at IS NULL)
LEFT JOIN topics t ON (t.user_id = u.id AND t.created_at::date = dr.date AND p.topic_id = t.id AND t.deleted_at IS NULL)
GROUP BY u.id, dr.date, dr.week
ORDER BY u.id, dr.date),
visits AS (SELECT u.id, dr.*, COALESCE(sum(posts_read),0) AS posts_read, COALESCE(sum(time_read),0) AS time_read, COUNT(uv.*) AS visits
FROM date_range dr
LEFT JOIN user_visits uv ON (uv.user_id = u.id AND visited_at = dr.date)
SELECT ps.id, ps.username, ps.created_at, CASE
WHEN :coverage::text = 'week' THEN ps.week::text
WHEN :coverage::text = 'all' THEN '-1'
ELSE ps.date::text
END  AS period, sum(ps.replies) AS replies, sum(ps.topics) AS topics, sum(ps.likes_received) AS likes_received, sum(lg.likes) AS likes_given, COALESCE(sum(posts_read),0) AS posts_read, COALESCE(sum(time_read),0) AS time_read, SUM(visits) AS visits
FROM posts_summary ps
LEFT JOIN likes_given lg ON (ps.date = lg.date AND ps.id = lg.id)
LEFT JOIN visits v ON (v.id = ps.id AND v.date = ps.date)
GROUP BY ps.id, ps.username, ps.created_at, CASE
ELSE ps.date::text
END
ORDER BY ps.id, CASE
ELSE ps.date::text
END
您可以使用此查询在指定的时间范围内按用户提取每日、每周或总计的统计数据。
输入参数:
  • start_date(字符串)例如 ‘2019-12-31’
  • end_date(字符串)例如 ‘2019-12-31’
  • coverage(枚举)选项包括:1) ‘date’ 表示每日统计,2) ‘week’ 表示每周统计,或 3) ‘all’ 表示总计统计
输出字段:
  • id(用户 ID)
  • username(用户名)
  • created_at(用户创建时间)
  • period(日期字符串,用于 ‘date’ 覆盖范围;周数,例如 12 月 26 日 -31 日 = 52,用于 ‘week’ 覆盖范围;或 -1,用于 ‘all’ 覆盖范围)
  • replies(非主题首帖的帖子数量)
  • topics(主题数量)
  • likes_received(收到的点赞数)
  • likes_given(给出的点赞数)
  • posts_read(已读帖子数)
  • time_read(阅读时长)
  • visits(访问次数)
您可能需要使用 API 来访问此查询的完整结果(尤其是长时间跨度的每日数据)。有关如何通过 API 触发查询的更多详情,请参阅 此帖子。
您可以使用此查询生成每日用户参与度的数据集。
7 个赞
