User Page Metrics
The discussion titled “User Page Metrics” involves retrieving user engagement metrics, such as likes received, likes given, topics viewed, posts read, days visited, solutions, and cheers, for a specific date range. srinivas.chilukuri initially requested a SQL query to achieve this, and SaraDev provided a query using the directory_items table. However, srinivas.chilukuri required a query with start and end dates, which led to SaraDev providing an updated query using separate Common Table Expressions (CTEs) for each metric.
The updated query uses the user_actions, user_stats, user_visits, topic_views, and gamification_scores tables to retrieve the required metrics. However, srinivas.chilukuri noticed discrepancies in the results, particularly for topics_entered, posts_read_count, and days_visited. SaraDev explained that the discrepancies stem from using the user_stats table instead of other tables like user_visits and topic_views to filter statistics by date.
To address this, SaraDev provided an updated query that uses the correct tables to filter metrics by date. The query includes CTEs for likes received, likes given, user metrics, solutions, and cheers, and joins these CTEs with the users table to retrieve the required metrics. Note that the posts_read data in the user_visits table does not count a user’s own posts, which may still cause differences between the query results and the User Page statistics. Jagster also encountered an error with the query, but it was not directly related to the main discussion.
@SaraDev
can u provide the sql query for metrics available at https://meta.discourse.org/u?cards=no&order=post_count
refer image below
metrics
  • like received
  • like given
  • topics viewed
  • posts read
  • days visited
  • solutions
  • cheers
we are utilizing category moderators hence we are modifying the moderator query to any given group
Hi @srinivas.chilukuri,
The /u user page statistics can be retrieved via the Data Explorer by using the directory_items table.
User Directory Page Metrics
-- [params]
-- int :period
-- Period Options:
-- 1. all
-- 2. yearly
-- 3. monthly
-- 4. weekly
-- 5. daily
-- 6. quarterly
SELECT
    di.user_id,
    COALESCE(di.likes_received, 0) AS likes_received,
    COALESCE(di.likes_given, 0) AS likes_given,
    COALESCE(di.topics_entered, 0) AS topics_viewed,
    COALESCE(di.topic_count, 0) AS topic_count,
    COALESCE(di.post_count, 0) AS post_count,
    COALESCE(di.days_visited, 0) AS days_visited,
    COALESCE(di.posts_read, 0) AS posts_read,
    COALESCE(di.solutions, 0) AS solutions,
    COALESCE(di.gamification_score, 0) AS cheers
FROM
    directory_items di
WHERE
    di.period_type = :period
ORDER BY
    di.user_id
Instead of the typical start_date and end_date parameters, data from this table can be filtered using the period_type field, where the following values correspond to the different time periods available on the directory page:
  • 1: all time
  • 2: yearly
  • 3: monthly
  • 4: weekly
  • 5: daily
  • 6: quarterly
Example Results for this report would look like:
user likes_received likes_given topics_viewed topic_count post_count days_visited posts_read solutions cheers
Username1 4 17 250 69 116 480 217 10 844100
Username2 2 5 47 0 2 43 59 1 112305
Username3 0 4 2 0 0 2 7 0 3100
@SaraDev
I require the start and end date . is there a workaround for getting the given metrics with start and end date
  • user
  • likes_received
  • likes_given
  • topics_viewed
  • topic_count
  • post_count
  • days_visited
  • posts_read
  • solutions
  • cheers
Note : I am getting metrics for a small subset of total users
If you want to view those metrics for users on your site and filter by specific start and end dates, you would need a query that pulls the data for each metric in a separate CTE, and then combine the results together in a final SELECT statement.
Here’s what that would look like:
User Metrics
-- [params]
-- date :start_date = 2020-01-01
-- date :end_date = 2025-01-01
WITH likes_received AS (
    SELECT
        ua.user_id AS user_id,
        COUNT(*) AS likes_received
    FROM
        user_actions ua
    WHERE
        ua.action_type = 2
        AND ua.created_at BETWEEN :start_date AND :end_date
    GROUP BY
        ua.user_id
likes_given AS (
    SELECT
        ua.acting_user_id AS user_id,
        COUNT(*) AS likes_given
    FROM
        user_actions ua
    WHERE
        ua.action_type = 1
    GROUP BY
        ua.acting_user_id
user_metrics AS (
    SELECT
        us.user_id,
        SUM(us.topics_entered) AS topics_viewed,
        SUM(us.posts_read_count) AS posts_read,
        SUM(us.days_visited) AS days_visited
    FROM
        user_stats us
    WHERE
        us.first_post_created_at BETWEEN :start_date AND :end_date
    GROUP BY
        us.user_id
solutions AS (
    SELECT
        COUNT(*) AS solutions
    FROM
        user_actions ua
    WHERE
        ua.action_type = 15
    GROUP BY
        ua.acting_user_id
cheers AS (
    SELECT
        gs.user_id,
        SUM(gs.score) AS cheers
    FROM
        gamification_scores gs
    WHERE
        gs.date BETWEEN :start_date AND :end_date
    GROUP BY
        gs.user_id
SELECT
    u.id AS user_id,
    COALESCE(lr.likes_received, 0) AS likes_received,
    COALESCE(lg.likes_given, 0) AS likes_given,
    COALESCE(um.topics_viewed, 0) AS topics_viewed,
    COALESCE(um.posts_read, 0) AS posts_read,
    COALESCE(um.days_visited, 0) AS days_visited,
    COALESCE(sol.solutions, 0) AS solutions,
    COALESCE(ch.cheers, 0) AS cheers
FROM
    users u
LEFT JOIN
    likes_received lr ON u.id = lr.user_id
LEFT JOIN
    likes_given lg ON u.id = lg.user_id
LEFT JOIN
    user_metrics um ON u.id = um.user_id
LEFT JOIN
    solutions sol ON u.id = sol.user_id
LEFT JOIN
    cheers ch ON u.id = ch.user_id
ORDER BY
    u.id
Query Explanation:
  1. Parameters:
  • :start_date and :end_date are parameters that define the date range for the data being queried.
  1. Common Table Expressions (CTEs):
  • likes_received: Counts the number of likes received by each user (action_type = 2) within the specified date range.
  • likes_given: Counts the number of likes given by each user (action_type = 1) within the specified date range.
  • user_metrics: Aggregates user statistics such as topics viewed, posts read, and days visited for users who made their first post within the specified date range.
  • solutions: Counts the number of solutions provided by each user (action_type = 15) within the specified date range.
  • cheers: Sums up the gamification scores for each user within the specified date range.
  1. Final Selection:
  • The main query selects user engagement metrics for each user, including likes received, likes given, topics viewed, posts read, days visited, solutions provided, and cheers received.
  • It uses LEFT JOIN to ensure all users are included, even if they have no activity in some categories, filling in with zeros using COALESCE.
Example Results
user_id likes_received likes_given topics_viewed posts_read days_visited solutions cheers
1 10 5 20 100 15 2 30
2 0 3 5 20 5 0 10
@SaraDev
We used the query provided in the post above and have the following questions:
  1. Is user_metrics from the user_stats table the correct source for this information? Given that user_stats is a static table summarizing a user’s metrics since they joined Discourse, it may not be ideal for filtering metrics within a specific time range (e.g., from a start date to an end date).
  2. Time-Series Comparison (T/S C/O)
    For a given set of users, we compared the available time-period data on the user page and noticed significant discrepancies.
Key Discrepancies:
  • topics_entered
  • posts_read_count
  • days_visited
Could you clarify if there’s a better way to retrieve time-bound user metrics?
PG::UndefinedColumn: ERROR:  column uv.topic_id does not exist
LINE 38:         COUNT(DISTINCT uv.topic_id) AS topics_viewed, -- Cou...
You are correct that the user_stats table is a static table summarizing a user’s lifetime metrics since they joined Discourse.
Instead, for filter metrics by date like posts_read_count and days_visited, we would want to use the user_visits database table for posts. We would also want to use the topic_views table for filtering the topics_entered metrics by date.
The discrepancies you observed stem from using the user_stats table instead of other tables like user_visits and topic_views to filter those statistics by date.
To address this, we can update the query to use those database tables instead:
Here’s an updated version of the query:
User Page Metrics
-- [params]
-- date :end_date = 2026-01-01
    SELECT
    FROM
        user_actions ua
    WHERE
        ua.action_type = 2
    GROUP BY
        ua.user_id
likes_given AS (
    SELECT
    FROM
        user_actions ua
    WHERE
        ua.action_type = 1
    GROUP BY
        ua.acting_user_id
user_metrics AS (
    SELECT
        tv.user_id,
        COUNT(DISTINCT tv.topic_id) AS topics_viewed
    FROM
        topic_views tv
    WHERE
        tv.viewed_at BETWEEN :start_date AND :end_date
    GROUP BY
        tv.user_id
days_and_posts AS (
    SELECT
        uv.user_id,
        COUNT(DISTINCT uv.visited_at) AS days_visited,
        SUM(uv.posts_read) AS posts_read
    FROM
        user_visits uv
    WHERE
        uv.visited_at BETWEEN :start_date AND :end_date
    GROUP BY
        uv.user_id
solutions AS (
    SELECT
    FROM
        user_actions ua
    WHERE
        ua.action_type = 15
    GROUP BY
        ua.acting_user_id
cheers AS (
    SELECT
        gs.user_id,
    FROM
    WHERE
    GROUP BY
        gs.user_id
SELECT
    u.id AS user_id,
    COALESCE(dp.days_visited, 0) AS days_visited,
    COALESCE(dp.posts_read, 0) AS posts_read,
FROM
    users u
LEFT JOIN
LEFT JOIN
LEFT JOIN
LEFT JOIN
    days_and_posts dp ON u.id = dp.user_id
LEFT JOIN
LEFT JOIN
ORDER BY
    u.id
Note that with this method, the posts_read data in the user_visits table has one important distinction - it does not count a user’s own posts, while the data from the user_stats table does include self-authored posts, so you may still find a difference between these two statistics in this query and on the User Page.
