Dark/light mode toggle now available in core
I tested it on his forum.
With system preference to Dark → it stays light.
With system preference to Dark and “Sombre” (dark) is selected → it stays light.
With system preference to Light when “Sombre” is selected → it switches to Dark.
I don’t see any icons either way. Hope that helps!
Does not show the option/icon on my forum either, unless logged out (guest).
Maybe there needs to be some sort of user preferences change for all forum members for this to work.
Edit: for now, I’ve reinstalled Sidebar Theme Toggle (which it looks like is being used bottom left on this forum as well) but will monitor this topic/plugin.
I can’t see the toggle either in sidebar or header. I’m able to switch the color theme in the user settings but the toggle doesn’t appear anywhere.
Maybe I missed this, but should I be able to see this here on meta? I have the theme set to default, but no toggle in the UI.
The sidebar and down there this:
if you are not seeing the light/dark toggle at the bottom of the sidebar, it likely means you do not have 2 color palettes selected in your preferences - you should have both a light and dark palette selected. if you use a “same as regular” or just one palette, you won’t get the setting.
Thanks! That was indeed the problem. I see the toggle now (it took a page refresh in the browser for it to show up, though).
I wonder what triggers the UI to show the Dark mode dropdown? My theme has two color palettes defined but the user can only select one at a time (see my screenshot in the previous message). I have the latest “tests-passed” version on my site.
I created a separate bug ticket earlier for the issues with the light/dark theme toggle.
A post was split to a new topic: Feature request: multiple default palettes in theme editor
