Dark/light mode toggle now available in core
The Dark/Light Mode Toggle feature is now available in Discourse core, allowing users to easily switch between light and dark modes. The feature can be enabled via the interface color selector site setting and has a third ‘Auto’ option that matches the system preference of the user’s device. Osama announced the feature and provided screenshots of the toggle in the sidebar footer and header. However, some users, such as Kevin7, reported issues with the toggle not appearing or not working as expected. Osama requested screenshots to help troubleshoot the issues. Kevin7 found a solution using CSS to fix the issue with button text color. Jagster suggested that the issue might be due to a conflict with other components or themes. StefanoCecere reported that the toggle was not showing on mobile devices, but Jagster showed that it was working on some iPhones. Osama explained that the toggle will only appear if both a light and a dark palette are selected in the user’s preferences. Patrick EMIN reported that he did not see the color palette setting in his preferences, but Osama clarified that the setting is only available if multiple dark palettes are available. Andrew_Rowe asked where to find the setting to turn on the feature, and Osama provided the location of the setting. Lilly explained that the toggle will not appear if only one color palette is selected in the user’s preferences. Ozzi reported that the toggle was not showing even though his theme has two color palettes defined, and Schneeland reported that the toggle appeared after selecting both light and dark palettes and refreshing the page.
The Dark/Light Mode Toggle theme component, which adds a toggle to allow users to easily switch between light and dark modes, has been merged into Discourse core and it can be enabled via the interface color selector site setting.
In addition to various bug fixes and improvements, the core version differs slightly from the original theme component in that it has a third “Auto” option which makes the site’s color mode match the system preference of the user’s device.
The color selector can be configured via the interface color selector site setting to appear either in the site header next to the search icon, or in the sidebar footer.
Here’s a screenshot when it’s in the sidebar footer:
And this is when it’s in the header:
Existing users of the theme component
We’ve deprecated the theme component and pushed a final update to make it detect if the core version is available and alert admins to delete it and enable the core version. Here’s a screenshot of the admin alert:
Once the core version is enabled, the theme component will no longer have an effect on your site. However, you should still completely delete it to prevent potential breakages in the future since we will no longer do any maintenance for the theme component.
Hello, thank you for this new feature, but I wonder why the buttons still have black text and icons when switching to dark mode instead of simply turning white. How can I make the text and icons on the buttons turn white when dark mode is active? Thank you.
Can you share a screenshot of the issue you’re seeing?
Here’s an example: when I switch Discourse to Dark Mode, some button texts remain black. I believe it would make more sense for the text to be white. However, I found a solution using CSS that I think works well to fix this issue.
$button-text-color: dark-light-choose(#ffffff, $primary);
:root {
  --button-text-color: #{$button-text-color};
.btn-primary {
  color: var(--button-text-color) !important;
  .d-icon {
That’s an intentional design decision on our part for primary buttons (the ones that have a blue background in the default color palette), so we won’t be changing it for everyone. That said, Discourse is very flexible and has a theming system for overriding core CSS.
I have already made the setting, but I am unable to see the option. Could you kindly explain the reason?
Do you have a light and dark palette selected in your preferences at /my/preferences/interface? The toggle will only appear if both a light and a dark palette are selected:
Hi, I do not see that color palette setting in my preferences, only “Theme” and “Dark mode”:
I believe if you enable the dark mode checkbox (I assume “Mode sombre” means dark mode in French), then the toggle will appear for you. Can you give that a try?
The color palettes preference in my last post above shows up if your site has multiple dark palettes that users can select from. If there’s only 1 color palette available, the dropdown menu is replaced with the checkbox that you see.
Really sorry… where is the setting for turning this feature on?
It doesn’t need install?
with new admin interface I’m a little disheveled
doesn’t show on mobile / iphone
on desktop: perfect.
i remember previous version (the Component version) showed.
Just showing that some iPhones and forums works.
It is in the core… that means it should show up when trying safe-mode, I guess. If that happens then it is conflict with some other componen, theme or plugin.
Otherwise
  • Discourse isn’t fresh enough
  • the toggle isn’t enabled in the site settings
  • dark mode isn’t enabled on site level or in the user settings
strange because it was working until a few days ago
i’ll come back in a few days.. lets’ see
thank you
i don’t have these two options… just the regular…
got it! but it was hard :slight_smile:
in a mix of several settings and personal preferences… i think we should make it easier to give a theme the two color schemes (dark and light)
Well no, it doesn’t appear in the sidebar footer.
If you go to /admin/site_settings/category/all_results?filter=interface_color_selector on your site you should be able to see the setting.
If you switch your system preference in your phone/computer from light to dark (or vice versa), does your discourse interface change to match the system preference or does it remain unchanged (in light or dark mode)?
Given that the core selector is working here and many other sites, there must be a configuration issue somewhere on your end that’s causing the selector to not be shown. Can you share the output of these commands when you run them in your browser console while you’re logged into your account?
(({dark_scheme_id, color_scheme_id}) => { return {dark_scheme_id, color_scheme_id}} )((await (await fetch(`/u/${Discourse.User.current().username}.json`)).json()).user.user_option)
Discourse.SiteSettings.default_dark_mode_color_scheme_id
Hi my setting is ok (bottom of sidebar). If I switch to Dark mode on mobile or PC, no it doesn’t give any change, and for the console, I do no know how to use it, sorry :grimacing:
But your dark color settings in system settings and/or your oersonal settings aren’t propably right.
Well probably, I always had difficultly about that type of settings, but it’s not so important, I’ll leave it like that, thanks for trying to help.
