Hey it won’t let me post again for 20 hours @darkpixlz
would it be possible to add a file like in the default theme that allows custom css? I can’t change username/group colours with your theme
That is core behavior, it only has the loading bar when you navigate pages, not reload. If it is always reloading, then you have a site issue.
Hi all,
A bit more unrelated, but soon I’ll be beginning a full restructure of the codebase. It’s buggy, messy, and breaks too often. I’ll rewrite the common script and add more mobile compatibility. There will also be more general design changes to be more modern and less “me in 2021”.
I’ll keep updates here. Stay tuned!
Hi,
Sorry I forgot to announce this yesterday but I made a bunch of changes to the general visual style. The buttons are now white, I fixed up some blur, and cleaned up the code a little bit. I also added my other addon Xreplace to the theme because I think the logo is horrible and don’t want it used with the theme lmao.
It wasn’t a huge update, but it should make it cleaner visually!
Hi all,
Pushed another update. Fixes the broken flagged UI, and I added mixins everywhere which should allow me to make everything more custom in the coming days. Enjoy!
Hi all,
Happy (almost) 2 years!
Currently, the theme is on version 1 (ignoring github’s “releases” which doesn’t really do much for the theme). It’s a bit of an inconsistent wreck and has a lot of issues. When I wrote the theme, I knew a little about CSS and no JS (and my UI/UX outside of dfiscourse looked something like this). Thankfully, this has changed a lot, so I plan on using that knowledge more in the rewrite. (it doesn’t need to be 2000 lines in it’s current state! fun fact: the theme used to just be my fork of the Air theme, i split it into its own thing after I got rid of the circle and added the blur)
I plan on releasing a Version 2 not too far in the future, with new code, a refreshed, modern look, and better compatibility with new features. Hoping to have more news here soon, hopefully by the summer! For updates you can check the dev-v2 branch of the theme which will start getting pushed to soon.
Sorry for leaving you all in the dark for a bit . Hopefully this new era will improve the theme for the better! I’ll start posting updates here pretty soon with design decisions (maybe a poll or two) and more. Thanks for your continued support as usual!
Hello,
I haven’t really been working on v2 (because the server my discourse dev instance was on had it’s hard drive explode when it touched an SSD i had in it ) but please update your repository URL (should be https://github.com/darkpixlz/DarkPixlz-s-Modern-Theme → https://github.com/pyxfluff/darkpixlz-Modern-Theme)! v2 may be published under a different topic because I can’t edit this one’s name and will likely have another name because “pyxfluff’s modern theme” doesn’t seem as professional
Thanks once again for the extended support and I promise for some better news soon!
Hi all,
Once again, sorry for the lack of updates. I still want to work on the rewrite but I’ve been doing other stuff. I got another test site up on my own PC this time and am hoping it’ll stay.
I quickly clicked around and noticed a couple of broken components. I’ll look into a fix for these hopefully soon.
Eventually the rewrite will happen - I just don’t know when.
What I am fixing is still in the air but I hope the fix will be soon (off the bat I’m noticing broken staff tags, broken blur, and some areas with solid backgrounds once again). Blur which is proben will likely not be fixed and saved for the rewrite.
If you have noticed any issues please also tell me so I can add it to my fixlist or tell you if it’s a WONTFIX for now.
Quick poll here to gauge interest on the design because I am in the drafting stages of it currently. Which one is better? Please vote in the poll, thanks
Thanks to those who voted in the poll. I’m starting the rewrite now on a new repository, you can track progress here for those interested:
Also if you want to track progress on the live demo you can use my test site (note it will only be online if I’m actively testing due to system resources):
Dumping progress as I go here unless I’m told to stop to keep people updated. Starting to make some major strides in the initial design, it’s not much but it’s a start currently
I have an issue in thread moderation.
When I go to select a post to delete or move:
There’s supposed to be a floating menu:
This happens in Edge/FF/Chrome.
As always, thanks so much for the great theme! Glad to see it still getting TLC.
That’s weird. Seems to be important so I’ll try fixing later this afternoon.
Hey man, i know it’s been some time since you worked on this theme, good job by the way. I wanted to say there is a bug not showing the views next to the replies and date table header above the topics. The views are shown on the left next to the avatar pic of the poster and there is no header telling you that that number is the views, the th element in the html although exists. Maybe you can fix that?
This has been an issue for a loooong time. I last tried fixing it in 2022 iirc but was not successful. It’ll get fixed if I ever go back to the rewrite but I haven’t been doing that because Ife had other priorities.
Maybe I’ll have a look some day though.A bugfix update isn’t fully out of the question though because there are a lot of long-standing issues I’m not fully qualified to fix but I. like still have a look.
Hi all,
I just spun up my first serious instance since… 2022. I’m aware that the composer and admin interface are not in great shape right now
I’ll see if I can make some quick patches. Thanks you for your continued support!
Hi all,
I have just made a lot of fixes which should solve a lot of issues you all were having before! Feel free to give it a try.
I tried checking on the user menu but I cannot figure out how to fix it’s background blur.. I’ll accept a pull request if somebody manages to fix it but I personally do not know how to fix it.
nice>.<
