Dashboard New Posts statistics broken
root@prometheus-discourse-sidemount:/var/www/discourse# rails c
Plugin name is 'discourse-docs', but plugin directory is named 'discourse-knowledge-explorer'
Plugin name is 'discourse-user-notes', but plugin directory is named 'discourse-staff-notes'
Loading production environment (Rails 7.2.2.1)
discourse(prod)> Post.public_posts_count_per_day(4.weeks.ago, Time.zone.now)
discourse(prod)>
A lot… :wink: Taken from the container config yaml:
https://github.com/discourse/docker_manager.git
https://github.com/discourse/discourse-adplugin.git
https://github.com/discourse/discourse-affiliate.git
https://github.com/discourse/discourse-ai.git
https://github.com/discourse/discourse-akismet.git
https://github.com/pfaffman/discourse-allow-pm-to-staff.git
https://github.com/discourse/discourse-animated-avatars.git
https://github.com/discourse/discourse-apple-auth.git
https://github.com/discourse/discourse-assign.git
https://github.com/discourse/discourse-authentication-validations.git
https://github.com/discourse/discourse-auto-deactivate.git
https://github.com/discourse/discourse-bbcode.git
https://github.com/discourse/discourse-bcc.git
https://github.com/discourse/discourse-cakeday.git
https://github.com/discourse/discourse-calendar.git
https://github.com/discourse/discourse-characters-required.git
https://github.com/discourse/discourse-chat-integration.git
https://github.com/discourse/discourse-data-explorer.git
https://github.com/discourse/discourse-fingerprint.git
https://github.com/discourse/discourse-follow.git
https://github.com/leodavidson/discourse-forcemoderation.git
https://github.com/discourse/discourse-gamification.git
https://github.com/discourse/discourse-hcaptcha.git
https://github.com/discourse/discourse-knowledge-explorer.git
https://github.com/angusmcleod/discourse-locations.git
https://github.com/discourse/discourse-login-with-amazon.git
https://github.com/discourse/discourse-math.git
https://github.com/discourse/discourse-microsoft-auth.git
https://github.com/discoursehosting/discourse-migratepassword.git
https://github.com/discourse/discourse-policy.git
https://github.com/paviliondev/discourse-post-badges-plugin.git
https://github.com/discourse/discourse-post-voting.git
https://github.com/communiteq/discourse-private-topics.git
https://github.com/discourse/discourse-push-notifications.git
https://github.com/featheredtoast/discourse-pushover-notifications.git
https://github.com/paviliondev/discourse-ratings.git
https://github.com/discourse/discourse-reactions.git
https://github.com/discourse/discourse-restricted-replies.git
https://github.com/discourse/discourse-saved-searches.git
https://github.com/discourse/discourse-shared-edits.git
https://github.com/discourse/discourse-signatures.git
https://github.com/discourse/discourse-solved.git
https://github.com/discourse/discourse-staff-alias.git
https://github.com/discourse/discourse-staff-notes.git
https://github.com/discourse/discourse-steam-login.git
https://github.com/singerscreations/discourse-stopforumspam.git
https://github.com/discourse/discourse-styleguide.git
https://github.com/discourse/discourse-subscriptions.git
https://github.com/davidtaylorhq/discourse-telegram-notifications.git
https://github.com/discourse/discourse-templates.git
https://github.com/discourse/discourse-tooltips.git
https://github.com/jannolii/discourse-topic-trade-buttons.git
https://github.com/discourse/discourse-topic-voting.git
https://github.com/discourse/discourse-translator.git
https://github.com/discourse/discourse-user-field-prompt.git
https://github.com/discourse/discourse-whos-online.git
https://github.com/discourse/discourse-yearly-review.git
Btw, as @qingfeng1024 is experiencing this problem as well, it does not seem to be a personal problem here. Maybe he can tell us also what the tests above show on/in the forum there and also what plugins are used?
@martin do you have any ideas about this issue?
No sorry this fell through the cracks a bit.
@qingfeng1024 does the exact same thing happen to you if you run this in your rails console?
MethodProfiler.output_sql_to_stderr!
Report.find("posts", start_date: 4.weeks.ago, end_date: Time.zone.now).data
You will see output like this post, can you copy + paste it here please? Dashboard New Posts statistics broken - #18 by Roi
@kris.kotlarek I haven’t had any luck here, can you see if anything stands out about this to you from this topic?
root@shannon-20250121-app:/var/www/discourse# rails c
Plugin name is 'DiscourseMatheditor', but plugin directory is named 'discourse-matheditor'
discourse(prod)> MethodProfiler.output_sql_to_stderr!
Stop! This instrumentation is not intended for use in production outside of debugging scenarios. Please be sure you know what you are doing when enabling this instrumentation.
=> true
discourse(prod)> Report.find("posts", start_date: 4.weeks.ago, end_date: Time.zone.now).data
debugsql (sql): SET client_min_messages TO 'warning'
debugsql (sec): 0.0
debugsql (sql): SET standard_conforming_strings = on
debugsql (sec): 0.0
debugsql (sql): SET intervalstyle = iso_8601
debugsql (sec): 0.0
debugsql (sql): SELECT t.oid, t.typname
FROM pg_type as t
WHERE t.typname IN ('int2', 'int4', 'int8', 'oid', 'float4', 'float8', 'numeric', 'bool', 'timestamp', 'timestamptz', 'date')
debugsql (sec): 0.001
debugsql (sql): SET SESSION timezone TO 'UTC'
debugsql (sec): 0.0
debugsql (sql): SELECT t.oid, t.typname, t.typelem, t.typdelim, t.typinput, r.rngsubtype, t.typtype, t.typbasetype
FROM pg_type as t
LEFT JOIN pg_range as r ON oid = rngtypid
WHERE
  t.typname IN ('int2', 'int4', 'int8', 'oid', 'float4', 'float8', 'text', 'varchar', 'char', 'name', 'bpchar', 'bool', 'bit', 'varbit', 'date', 'money', 'bytea', 'point', 'hstore', 'json', 'jsonb', 'cidr', 'inet', 'uuid', 'xml', 'tsvector', 'macaddr', 'citext', 'ltree', 'line', 'lseg', 'box', 'path', 'polygon', 'circle', 'numeric', 'interval', 'time', 'timestamp', 'timestamptz')
debugsql (sec): 0.002
FROM pg_type as t
WHERE
  t.typtype IN ('r', 'e', 'd')
FROM pg_type as t
WHERE
  t.typelem IN (16, 17, 18, 19, 20, 21, 23, 25, 26, 114, 142, 600, 601, 602, 603, 604, 628, 700, 701, 718, 790, 829, 869, 650, 1042, 1043, 1082, 1083, 1114, 1184, 1186, 1560, 1562, 1700, 2950, 3614, 3802, 16924, 88307, 88314, 106343, 106350, 13223, 13226, 13228, 13234, 13236, 3904, 3906, 3908, 3910, 3912, 3926)
debugsql (sql): SELECT a.attname, format_type(a.atttypid, a.atttypmod),
       pg_get_expr(d.adbin, d.adrelid), a.attnotnull, a.atttypid, a.atttypmod,
       c.collname, col_description(a.attrelid, a.attnum) AS comment,
       attidentity AS identity,
       attgenerated as attgenerated
  FROM pg_attribute a
  LEFT JOIN pg_attrdef d ON a.attrelid = d.adrelid AND a.attnum = d.adnum
  LEFT JOIN pg_type t ON a.atttypid = t.oid
  LEFT JOIN pg_collation c ON a.attcollation = c.oid AND a.attcollation <> t.typcollation
 WHERE a.attrelid = '"themes"'::regclass
   AND a.attnum > 0 AND NOT a.attisdropped
 ORDER BY a.attnum
debugsql (sql): SHOW max_identifier_length
debugsql (sec): 0.0
debugsql (sql): ;
debugsql (sec): 0.0
  FROM (
         SELECT indrelid, indkey, generate_subscripts(indkey, 1) idx
           FROM pg_index
          WHERE indrelid = '"themes"'::regclass
            AND indisprimary
       ) i
  JOIN pg_attribute a
    ON a.attrelid = i.indrelid
   AND a.attnum = i.indkey[i.idx]
 ORDER BY i.idx
debugsql (sec): 0.008
debugsql (sql): SELECT "themes".* FROM "themes" WHERE "themes"."id" = 2 ORDER BY "themes"."id" ASC LIMIT 1
debugsql (sec): 0.0
debugsql (sql): ;
debugsql (sec): 0.0
  FROM (
           FROM pg_index
          WHERE indrelid = '"color_schemes"'::regclass
            AND indisprimary
       ) i
  JOIN pg_attribute a
 ORDER BY i.idx
debugsql (sql): ;
debugsql (sec): 0.0
  FROM pg_attribute a
 WHERE a.attrelid = '"color_schemes"'::regclass
 ORDER BY a.attnum
debugsql (sql): ;
debugsql (sec): 0.0
debugsql (sql): SELECT "color_schemes".* FROM "color_schemes" WHERE (color_schemes.id NOT IN (SELECT color_scheme_id FROM theme_color_schemes)) AND "color_schemes"."id" = 5 LIMIT 1
debugsql (sql): ;
debugsql (sec): 0.0
  FROM (
           FROM pg_index
          WHERE indrelid = '"color_scheme_colors"'::regclass
            AND indisprimary
       ) i
  JOIN pg_attribute a
 ORDER BY i.idx
debugsql (sql): ;
debugsql (sec): 0.0
  FROM pg_attribute a
 WHERE a.attrelid = '"color_scheme_colors"'::regclass
 ORDER BY a.attnum
debugsql (sql): ;
debugsql (sec): 0.0
debugsql (sql): SELECT "color_scheme_colors".* FROM "color_scheme_colors" WHERE "color_scheme_colors"."color_scheme_id" = 5 ORDER BY id ASC
debugsql (sql): BEGIN
debugsql (sec): 0.0
debugsql (sql): SET TRANSACTION READ ONLY
debugsql (sql): SET LOCAL statement_timeout = 20000
debugsql (sec): 0.0
  FROM pg_attribute a
 WHERE a.attrelid = '"posts"'::regclass
 ORDER BY a.attnum
debugsql (sec): 0.0
debugsql (sec): 0.0
debugsql (sec): 0.0
FROM pg_type as t
debugsql (sec): 0.003
  FROM pg_attribute a
 WHERE a.attrelid = '"category_custom_fields"'::regclass
 ORDER BY a.attnum
debugsql (sec): 0.005
debugsql (sql): SELECT "category_custom_fields"."category_id" FROM "category_custom_fields" WHERE "category_custom_fields"."name" = 'private_topics_enabled'
FROM pg_type as t
WHERE
  FROM (
           FROM pg_index
          WHERE indrelid = '"topics"'::regclass
            AND indisprimary
       ) i
  JOIN pg_attribute a
 ORDER BY i.idx
FROM pg_type as t
WHERE
FROM pg_type as t
WHERE
debugsql (sec): 0.009
  FROM (
           FROM pg_index
          WHERE indrelid = '"posts"'::regclass
            AND indisprimary
       ) i
  JOIN pg_attribute a
 ORDER BY i.idx
debugsql (sec): 0.007
  FROM pg_attribute a
 WHERE a.attrelid = '"topics"'::regclass
 ORDER BY a.attnum
debugsql (sql): SELECT COUNT(*) AS "count_all", date(posts.created_at) AS "date_posts_created_at" FROM "posts" INNER JOIN "topics" ON "topics"."deleted_at" IS NULL AND "topics"."id" = "posts"."topic_id" WHERE "posts"."deleted_at" IS NULL AND (topics.archetype <> 'private_message') AND NOT ((topics.category_id IN (NULL))) AND (posts.created_at >= '2025-03-03 06:42:19.865947' AND posts.created_at <= '2025-03-31 06:42:19.866261') AND "posts"."post_type" = 1 GROUP BY date(posts.created_at) ORDER BY date(posts.created_at)
debugsql (sec): 0.0
debugsql (sql): SELECT COUNT(*) FROM "posts" INNER JOIN "topics" ON "topics"."deleted_at" IS NULL AND "topics"."id" = "posts"."topic_id" WHERE "posts"."deleted_at" IS NULL AND (topics.archetype <> 'private_message') AND NOT ((topics.category_id IN (NULL))) AND "posts"."post_type" = 1
debugsql (sec): 0.0
debugsql (sql): SELECT COUNT(*) FROM "posts" INNER JOIN "topics" ON "topics"."deleted_at" IS NULL AND "topics"."id" = "posts"."topic_id" WHERE "posts"."deleted_at" IS NULL AND (topics.archetype <> 'private_message') AND NOT ((topics.category_id IN (NULL))) AND "posts"."post_type" = 1 AND (posts.created_at >= '2025-02-01 06:42:19.865947' and posts.created_at < '2025-03-03 06:42:19.865947')
debugsql (sec): 0.0
debugsql (sql): COMMIT
debugsql (sec): 0.0
discourse(prod)>
The above is the output from my console.
I have installed several plugins; however, after entering safe mode in the browser, the backend still does not display the post count. I am uncertain where the issue lies, as all other statistics appear to be functioning normally—only the post count yields no results whatsoever.
Thanks! Your queries have the same odd AND NOT ((topics.category_id IN (NULL))) clause that I can’t figure out the origin of. At least we can rule out plugins if this happens in safe mode too.
I think this may be a server side issue that safe mode doesn’t disable.
It looks like you both have the Private Topics Plugin installed. I think it may be an issue with that. Possibly this commit from January? SECURITY: remove private topics category from public_posts · communiteq/discourse-private-topics@08c9668 · GitHub
Nice catch and I agree that the plugin should not insert that line if there are no private categories set (will update later today)
But I’m failing to see how it can break the dashboard?
I’m not entirely sure, but when I install the Private Topics plugin on my test site I can repro this issue. It seems to be when I don’t have any category set with ‘enable private topics’ in the category security settings (even if the plugin is installed but disabled). If I set a category to have Private Topics enabled then my dashboard report is populated again.
I think it may be that the amended report doesn’t like the NULL value in the extra condition?
I have been able to reproduce the issue and I have pushed a fix.
Thank you @JammyDodger , I’m not sure how long it would have taken me to find this.
(Good to see you back)
Great thank you all! That was a hard one to solve…
Ah amazing thanks @JammyDodger , this was driving me nuts :zany_face:
