דוח דשבורד - פוסטים
סיכום מבוסס בינה מלאכותית
The discussion revolves around an SQL query for a Dashboard Report - Posts, which tracks daily post counts within a specified date range, excluding private messages and deleted posts. SaraDev shares an initial query that filters for regular topics and post types. tknospdr requests modifications to include category/subcategory filters and user-specific data for support ticket analysis. SaraDev provides an enhanced query that allows filtering by category, user, and includes an option to incorporate subcategories. The final query outputs post counts by user and date, which tknospdr finds helpful.
This is an SQL version of the Dashboard Report for Posts.
This report provides a daily count of posts created within a specified date range. It is designed to track the activity in regular topics, excluding posts from private messages and other special archetypes.
--[params]
-- date :start_date
-- date :end_date
SELECT
    p.created_at::date AS "Day",
    COUNT(p.id) AS "Count"
FROM posts p
INNER JOIN topics t ON t.id = p.topic_id AND t.deleted_at ISNULL
WHERE p.created_at::date BETWEEN :start_date AND :end_date
    AND p.deleted_at ISNULL
    AND t.archetype = 'regular'
    AND p.post_type = 1
GROUP BY p.created_at::date
ORDER BY 1
SQL Query Explanation
  • Parameters:
    • The query accepts two parameters, :start_date and :end_date, which define the date range for the report. Both date parameters accept the date format of YYYY-MM-DD.
The SQL query performs the following operations:
  • Data Selection:
    • It selects the date (created_at::date) when each post was created and casts it to a date format to ignore the time component.
    • It also counts the number of posts (COUNT(p.id)) created on each date.
  • Joins:
    • The query joins the posts table with the topics table using an INNER JOIN. This join ensures that only posts associated with existing topics are considered.
    • It filters out any topics that have been deleted (t.deleted_at ISNULL).
  • Filters:
    • It filters posts to include only those within the specified date range (p.created_at::date BETWEEN :start_date AND :end_date).
    • It excludes deleted posts (p.deleted_at ISNULL).
    • It restricts the results to posts from regular topics (t.archetype = 'regular').
    • It considers only p.post_type = 1 posts, excluding moderator actions, whispers, and small_action posts.
  • Grouping and Ordering:
    • The results are grouped by the date of post creation (GROUP BY p.created_at::date).
    • The final output is ordered by the date in ascending order (ORDER BY 1), where 1 refers to the first column in the SELECT statement, which is the date.
Example Results
Day Count
2023-11-12 25
2023-11-13 35
2023-11-14 38
2023-11-15 47
2023-11-16 36
2023-11-17 79
זה נהדר.
האם תהיה דרך להגדיר את הקטגוריה/תת-קטגוריה בזמן ריצה כתאריך?
ובבונוס, האם נוכל לרשום את התוצאות לפי משתמש, או להגדיר גם את המשתמש?
מה שאני מנסה לעשות זה לראות כמה פוסטים נעשו במהלך (טווח) באזורי כרטיסי התמיכה שלי על ידי צוות התמיכה שלי.
Yes, you can use the following query for this:
--[params]
-- date :start_date
-- date :end_date
-- null category_id :category_id
-- null user_id :user_id
-- boolean :include_subcategories = false
SELECT
    u.username AS "User",
    p.created_at::date AS "Date",
FROM posts p
INNER JOIN topics t ON t.id = p.topic_id AND t.deleted_at IS NULL
INNER JOIN users u ON p.user_id = u.id
LEFT JOIN categories c ON t.category_id = c.id
    AND p.deleted_at IS NULL
    AND p.post_type = 1
    AND (
        :category_id IS NULL
        OR t.category_id = :category_id
        OR (:include_subcategories AND c.parent_category_id = :category_id)
    AND (:user_id IS NULL OR p.user_id = :user_id)
GROUP BY u.username, p.created_at::date
ORDER BY p.created_at::date ASC, u.username
Parameters:
  • :start_date & :end_date: Define the reporting timeframe (required)
  • :category_id: Optional filter for a specific category
  • :user_id: Optional filter for a specific user
  • :include_subcategories: Option to include subcategories of the chosen category
This query shows:
  • User: Username of the post author
  • Date: The calendar date when posts were created
  • Count: Number of posts created by that user on that date
Example Data:
User Date Count
user 1 2023-01-01 3
user 2 2023-01-01 2
user 3 2023-01-01 1
user 1 2023-01-02 2
user 2 2023-01-02 3
user 1 2023-01-03 1
תודה, זה עוזר מאוד!
