דוח דשבורד - הנושאים המובילים שהופנו אליהם
This is an SQL version of the Dashboard Report for Top Referred Topics
This report will display topics that have received the most clicks from external sources.
--[params]
-- date :start_date
-- date :end_date
SELECT
    p.topic_id,
  COUNT(*) AS external_click_count
FROM incoming_links il
INNER JOIN posts p ON p.id = il.post_id
WHERE il.created_at::date BETWEEN :start_date AND :end_date
    AND p.deleted_at ISNULL
GROUP BY p.topic_id
ORDER BY external_click_count DESC
How It Works
  • The query selects the topic_id from the posts table and counts the number of incoming links associated with each post.
  • It filters the incoming links based on the created_at date to fall between :start_date and :end_date.
  • Only non-deleted posts are considered in the count (p.deleted_at IS NULL).
  • Results are grouped by topic_id to aggregate the count of external clicks per topic.
  • The list is ordered in descending order of external_click_count to show the topics with the most external clicks at the top.
Example Results
topic external_click_count
topic 1 1234
topic 2 456
topic 3 78
3 לייקים
