"Exportação de dados concluída", mas o download não funciona
Anyone can help me with this issue below?
Thank you!
Are you seeing any relevant error in /logs?
I am not the server admin. Can I somehow get the logs via the web interface?
Yes, I meant - forum.example.com/logs.
Does this help?
Are you hosted on Bitnami? That’s not officially supported. I recommend taking a backup and restoring on Discourse docker setup using our official install guide.
No, we are hosted on GCP (Google Cloud Platform).
Bitnami has partnered with Google, so you’re actually using a Bitnami installation that we don’t support. It’s possible that your version of Discourse is an old version with a bug. You should reinstall your site as @techAPJ mentioned in his reply or ask support to Bitnami via GCP.
@dax @techAPJ thanks for your help! Will follow up with them then.
