Decorating all external links
Hello,
I’d like to mark external links (links except from own domain) with an arrow through css.. Do I need to modify all es6 functions that parse links or is there simple way?
if (DiscourseURL.isInternal(href))
Also I’m not sure if this is definitive list of sources where links are parsed and styled
_showLinkCounts()  in /app/assets/javascripts/discourse/widgets/post-cooked.js.es6
linkHtml(link) in app/assets/javascripts/discourse/widgets/post-links.js.es6
html(attrs, state) in /app/assets/javascripts/discourse/widgets/topic-map.js.es6
Thanks in advance!
You can get close using only CSS eg.
div.cooked a[rel="nofollow"]::after {
  content: "\2794";
One potential issue, if you have nofollow removed for your TL3 members.
Cool tip! Thanks, I’ll give it a try..
If you don’t like that arrow you could try others (replace the “U+” with a backslash).
“\2794” looks like this
You can also use all Font Awesome icons with:
    content: "\f0c1";
    font: normal normal normal 14px/1 FontAwesome;
