弃用通知:EmbeddableHost 的 class_name 字段已被弃用
您好,我知道警告不是错误,但我还是分享这个警告,因为它经常出现在我们的日志中。我无法确定它是否来自某个扩展,而且它引用的是一个旧的 Discourse 版本:
弃用通知:EmbeddableHost 的 class_name 字段已被弃用。请改用将 class_name 作为参数传递。(已在 Discourse 3.1.0.beta1 中弃用) (将在 Discourse 3.2 中移除)
在 /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/callbacks.rb:403:in block in make_lambda
堆栈跟踪:
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:130:in `block in warn'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:231:in `block in dispatch'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:231:in `each'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:231:in `dispatch'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:130:in `warn'
/var/www/discourse/lib/discourse.rb:1035:in `deprecate'
/var/www/discourse/app/controllers/embed_controller.rb:170:in `prepare_embeddable'
activesupport-7.1.5/lib/active_support/callbacks.rb:403:in `block in make_lambda'
activesupport-7.1.5/lib/active_support/callbacks.rb:183:in `block (2 levels) in halting_and_conditional'
actionpack-7.1.5/lib/abstract_controller/callbacks.rb:34:in `block (2 levels) in <module:Callbacks>'
activesupport-7.1.5/lib/active_support/callbacks.rb:184:in `block in halting_and_conditional'
activesupport-7.1.5/lib/active_support/callbacks.rb:598:in `block in invoke_before'
activesupport-7.1.5/lib/active_support/callbacks.rb:598:in `each'
activesupport-7.1.5/lib/active_support/callbacks.rb:598:in `invoke_before'
activesupport-7.1.5/lib/active_support/callbacks.rb:119:in `block in run_callbacks'
/var/www/discourse/app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
i18n-1.14.6/lib/i18n.rb:353:in `with_locale'
/var/www/discourse/app/controllers/application_controller.rb:424:in `with_resolved_locale'
activesupport-7.1.5/lib/active_support/callbacks.rb:130:in `block in run_callbacks'
activesupport-7.1.5/lib/active_support/callbacks.rb:141:in `run_callbacks'
actionpack-7.1.5/lib/abstract_controller/callbacks.rb:258:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/rescue.rb:25:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/instrumentation.rb:74:in `block in process_action'
activesupport-7.1.5/lib/active_support/notifications.rb:206:in `block in instrument'
activesupport-7.1.5/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport-7.1.5/lib/active_support/notifications.rb:206:in `instrument'
actionpack-7.1.5/lib/action_controller/metal/instrumentation.rb:73:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/params_wrapper.rb:261:in `process_action'
activerecord-7.1.5/lib/active_record/railties/controller_runtime.rb:32:in `process_action'
actionpack-7.1.5/lib/abstract_controller/base.rb:160:in `process'
actionview-7.1.5/lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler-3.3.1/lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionpack-7.1.5/lib/action_controller/metal.rb:227:in `dispatch'
actionpack-7.1.5/lib/action_controller/metal.rb:309:in `dispatch'
actionpack-7.1.5/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack-7.1.5/lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:51:in `block in serve'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:131:in `block in find_routes'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:124:in `each'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:124:in `find_routes'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-7.1.5/lib/action_dispatch/routing/route_set.rb:882:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack-2.2.10/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.10/lib/rack/conditional_get.rb:27:in `call'
rack-2.2.10/lib/rack/head.rb:12:in `call'
actionpack-7.1.5/lib/action_dispatch/http/permissions_policy.rb:36:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:397:in `call'
/var/www/discourse/lib/middleware/csp_script_nonce_injector.rb:12:in `call'
/var/www/discourse/config/initializers/008-rack-cors.rb:14:in `call'
rack-2.2.10/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.10/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/cookies.rb:689:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
activesupport-7.1.5/lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack-7.1.5/lib/action_dispatch/middleware/callbacks.rb:28:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
logster-2.20.0/lib/logster/middleware/reporter.rb:40:in `call'
/var/www/discourse/lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:35:in `call_app'
/var/www/discourse/lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:20:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/request_id.rb:28:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:24:in `call'
rack-2.2.10/lib/rack/method_override.rb:24:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/executor.rb:14:in `call'
rack-2.2.10/lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler-3.3.1/lib/mini_profiler.rb:191:in `call'
/var/www/discourse/lib/middleware/processing_request.rb:12:in `call'
message_bus-4.3.8/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:360:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/remote_ip.rb:92:in `call'
railties-7.1.5/lib/rails/engine.rb:536:in `call'
railties-7.1.5/lib/rails/railtie.rb:226:in `public_send'
railties-7.1.5/lib/rails/railtie.rb:226:in `method_missing'
rack-2.2.10/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.10/lib/rack/urlmap.rb:58:in `each'
rack-2.2.10/lib/rack/urlmap.rb:58:in `call'
unicorn-6.1.0/lib/unicorn/http_server.rb:634:in `process_client'
unicorn-6.1.0/lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn-6.1.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
