Avis de dépréciation : SiteSetting.enable_personal_messages a été déprécié. Veuillez utiliser SiteSetting.personal_message_enabled_groups à la place. (suppression dans Discourse 3.0) Dans /var/www/discourse/lib/
Trace :
Trace
/var/www/discourse/lib/discourse.rb:975:in `deprecate'
/var/www/discourse/lib/site_settings/deprecated_settings.rb:27:in `block (2 levels) in setup_deprecated_methods'
/var/www/discourse/lib/site_setting_extension.rb:199:in `public_send'
/var/www/discourse/lib/site_setting_extension.rb:199:in `block in client_settings_json_uncached'
/var/www/discourse/lib/site_setting_extension.rb:198:in `map'
/var/www/discourse/lib/site_setting_extension.rb:198:in `client_settings_json_uncached'
/var/www/discourse/lib/site_setting_extension.rb:190:in `block in client_settings_json'
/var/www/discourse/lib/cache.rb:89:in `fetch'
/var/www/discourse/lib/site_setting_extension.rb:189:in `client_settings_json'
/var/www/discourse/app/controllers/application_controller.rb:631:in `preload_anonymous_data'
/var/www/discourse/app/controllers/application_controller.rb:434:in `preload_json'
activesupport-7.0.4.3/lib/active_support/callbacks.rb:400:in `block in make_lambda'
activesupport-7.0.4.3/lib/active_support/callbacks.rb:199:in `block (2 levels) in halting'
actionpack-7.0.4.3/lib/abstract_controller/callbacks.rb:34:in `block (2 levels) in <module:Callbacks>'
activesupport-7.0.4.3/lib/active_support/callbacks.rb:200:in `block in halting'
activesupport-7.0.4.3/lib/active_support/callbacks.rb:595:in `block in invoke_before'
activesupport-7.0.4.3/lib/active_support/callbacks.rb:595:in `each'
activesupport-7.0.4.3/lib/active_support/callbacks.rb:595:in `invoke_before'
activesupport-7.0.4.3/lib/active_support/callbacks.rb:116:in `block in run_callbacks'
/var/www/discourse/app/controllers/application_controller.rb:414:in `block in with_resolved_locale'
i18n-1.12.0/lib/i18n.rb:322:in `with_locale'
/var/www/discourse/app/controllers/application_controller.rb:414:in `with_resolved_locale'
activesupport-7.0.4.3/lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport-7.0.4.3/lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack-7.0.4.3/lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack-7.0.4.3/lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack-7.0.4.3/lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport-7.0.4.3/lib/active_support/notifications.rb:206:in `block in instrument'
activesupport-7.0.4.3/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport-7.0.4.3/lib/active_support/notifications.rb:206:in `instrument'
actionpack-7.0.4.3/lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack-7.0.4.3/lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord-7.0.4.3/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack-7.0.4.3/lib/abstract_controller/base.rb:151:in `process'
actionview-7.0.4.3/lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler-3.0.0/lib/mini_profiler/profiling_methods.rb:85:in `block in profile_method'
actionpack-7.0.4.3/lib/action_controller/metal.rb:188:in `dispatch'
actionpack-7.0.4.3/lib/action_controller/metal.rb:251:in `dispatch'
actionpack-7.0.4.3/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack-7.0.4.3/lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack-7.0.4.3/lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
actionpack-7.0.4.3/lib/action_dispatch/routing/mapper.rb:48:in `serve'
actionpack-7.0.4.3/lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack-7.0.4.3/lib/action_dispatch/journey/router.rb:32:in `each'
actionpack-7.0.4.3/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-7.0.4.3/lib/action_dispatch/routing/route_set.rb:852:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:74:in `call'
rack-2.2.6.4/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.6.4/lib/rack/conditional_get.rb:27:in `call'
rack-2.2.6.4/lib/rack/head.rb:12:in `call'
actionpack-7.0.4.3/lib/action_dispatch/http/permissions_policy.rb:38:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:367:in `call'
rack-2.2.6.4/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.6.4/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-7.0.4.3/lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack-7.0.4.3/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport-7.0.4.3/lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack-7.0.4.3/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack-7.0.4.3/lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack-7.0.4.3/lib/action_dispatch/middleware/show_exceptions.rb:26:in `call'
logster-2.12.2/lib/logster/middleware/reporter.rb:43:in `call'
railties-7.0.4.3/lib/rails/rack/logger.rb:40:in `call_app'
railties-7.0.4.3/lib/rails/rack/logger.rb:27:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:20:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
actionpack-7.0.4.3/lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack-7.0.4.3/lib/action_dispatch/middleware/request_id.rb:26:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:24:in `call'
rack-2.2.6.4/lib/rack/method_override.rb:24:in `call'
actionpack-7.0.4.3/lib/action_dispatch/middleware/executor.rb:14:in `call'
rack-2.2.6.4/lib/rack/sendfile.rb:110:in `call'
actionpack-7.0.4.3/lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler-3.0.0/lib/mini_profiler/profiler.rb:249:in `call'
message_bus-4.3.2/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:228:in `call'
railties-7.0.4.3/lib/rails/engine.rb:530:in `call'
railties-7.0.4.3/lib/rails/railtie.rb:226:in `public_send'
railties-7.0.4.3/lib/rails/railtie.rb:226:in `method_missing'
rack-2.2.6.4/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.6.4/lib/rack/urlmap.rb:58:in `each'
rack-2.2.6.4/lib/rack/urlmap.rb:58:in `call'
unicorn-6.1.0/lib/unicorn/http_server.rb:634:in `process_client'
unicorn-6.1.0/lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn-6.1.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
Y a-t-il un moyen élégant d’identifier le plugin problématique ?
Est-il visible dans la trace ?
J’adore les journaux d’erreurs, Discourse est un petit bijou ![]()
Si vous pouvez m’aider à mieux comprendre et à l’utiliser…
Merci de votre aide !
