djcyry
(Cosmin)
September 24, 2017, 8:22pm
1
Hello ,
How can i add different logos for booth theme ?
I mean , for black theme a white logo (i have it already)
But for the light theme , a black logo ?
Black theme :
Light theme:
Also , is there any option to add a button for night/day mode in index , to change the theme ?
Thanks.
riking
(Kane York)
September 24, 2017, 10:34pm
Try changing the theme here - note that thereās a partial white background included in the logo. You could do the same with an off-black background.
edit: Screenshot
djcyry
(Cosmin)
September 24, 2017, 10:36pm
3
Ok , i will try with the photoshop (poor skills )
What about this :
cpradio
(cpradio)
September 24, 2017, 10:37pm
4
If you check the āTheme can be selected by usersā checkbox in Admin > Customize, it will show up as a link in the Hamburger menu.
djcyry
(Cosmin)
September 24, 2017, 10:38pm
5
Yes i know .
But i want to add a float button on index to do that .
Its a bad idea ? Just ask . Thanks
cpradio
(cpradio)
September 25, 2017, 12:07pm
6
That could likely be done via a customization, but it would involve JavaScript and some CSS to style the button. Not sure how hard it would be to do, but I imagine it shouldnāt be terribly difficult as the themes should be exposed via the API.
sam
(Sam Saffron)
September 26, 2017, 7:11am
7
I covered the technique here btw:
This is actually pretty simple:
old method .logo-big {
display: block;
-moz-box-sizing: border-box;
background: url(awesome-dark-logo.png) no-repeat;
width: 150px;
height: 40px;
padding-left: 150px;
background-size: 150px 40px;
You basically evict the existing image out of the IMG tag
n-b-sonar
(Nicolas)
December 6, 2018, 10:14am
8
Am getting reports on our instance that @sam techniques (css trick ) no longer works, and instead leads to double logo:
Is this a regression ? Any recommendation to mitigate this ?
Thanks!
david
(David Taylor)
December 6, 2018, 10:21am
9
The best method now is to use this theme component:
https://meta.discourse.org/t/alternative-logo-for-dark-themes/88502?u=david
I will update the post you linked so it doesnāt confuse people in future.
Hi, is this plugin still available?
Is there currently a solution for this? The link is not available anymore @david .
david
(David Taylor)
March 29, 2022, 2:38pm
12
You can now upload ādark modeā versions of your logo in the site settings. Just head to the branding tab, and scroll down to ālogo darkā and ālogo small darkā:
More information here:
You can now set up your Discourse site to automatically switch color schemes when the userās device is in dark mode. For a quick preview, head over to the try.discourse.org instance and toggle your deviceās dark mode on and off to see this new feature in action. (This feature not enabled on meta.)
Enabling automatic dark mode
To enable this feature on your instance, you can pick the dark mode color scheme in your site settings:
[image]
Once that setting is set, you can reload your site with ā¦
david
(David Taylor)
Split this topic
March 30, 2022, 8:28am
13
david
(David Taylor)
Closed
April 29, 2022, 8:28am
14
