Difficult to work out reason for Http 422 error in api
Resolving Http 422 Error in Discourse API
User paultaylor encountered a Http 422 error while importing topics into Discourse via API, indicating that the request syntax is fine but there’s an issue with the data. However, the error message doesn’t specify the exact problem, making it difficult to troubleshoot.
In paultaylor’s case, the issue was a title being too short and, later, a duplicate title. simon suggested setting the skip_validations parameter to true to avoid 422 errors caused by site settings. paultaylor found this solution helpful but noted that it’s not documented at https://docs.discourse.org/. simon acknowledged this and promised to add the documentation. paultaylor later confirmed that the skip_validations solution works.
I am running a test import of topics into discourse, for some topics I get error 422. I understand this basically means the syntax of the request is fine but there is something wrong with the data, but it doesn’t tell you what is wrong with the data making it difficult to work out
For example I spent ages trying to work out what was wrong with one topic, and because the body of the message was quite long and there were various punctuation characters I thought the problem might be with them, so I kept cutting it down and down and it made no difference.
Eventually I worked out it was because the topic title was too short as the default minimum was 15, and mine was 13, so I amended some values in settings, but much better if the api told me (or maybe it does and I missed it)
I currently have problem with the topic creation below, I can see nothing unusual about it, and category id is valid, any ideas ?
SEVERE: RESPONSE_CODE:422:REQUEST_JSON:{"title":"Urgent Jaikoz 1.9.2:Released","raw":"There was still a problem outstanding with the previous release with regards to MusicBRainz functionality, please update immediately.\r\n\r\nMore details at http://www.jthink.net/jaikoz/jsp/news/start.jsp ","category":1358,"created_at":"2007-05-24 10:06:20"}
In this case found the problem the title was a duplicate title (after stripping of a trailing blank). I guess the process is to manually create in User Interface and see what happens
When publishing posts to Discourse with the API, you can set the skip_validations parameter to true to avoid 422 errors for posts that would be disallowed by your site’s settings.
That is great, thankyou.
But wish I had known about this before, is it documented at https://docs.discourse.org/ I can’t see it ?
No, but I will add it there.
Confirmed that does indeed work
