Digest Emails and HTTPS
Hello!
We’ve set up Discourse to run over HTTPS, which works just fine. However, we’ve recently noticed that the digest email embeds HTTP links rather than HTTPS links. I’ve taken a look through the admin console but can’t find a setting that configures this.
Is it possible to set things up so the digest email embeds links using HTTPS instead?
Thanks,
-Mic
Did you enable the site setting use https?
I had not, but I have now. Thanks @fefrei. :]
I have looked through all the admin panels for ‘use https’ and I cannot find it. Where is this setting?
I believe it’s force_https now.
I did a search inside settings after manually searching all the panels and I do not see either ‘force_https’ or ‘use_https’.
Are you self-hosted or using a hosting service?
We are using Discourse’s Hosting service. It turns out it is handled differently and support fixed it for us.
Hola, tenemos este problema y estamos haciendo el autoalojamiento. ¿Cómo lo solucionamos? ¡Gracias!
Tendrás que entrar en la consola de Rails y habilitar la configuración del sitio force_https en ella.
