This guide provides instructions for administrators on how to disable two-factor authentication (2FA) via the console.
Required user level: System Admin
Console access required
This guide should only be used when 2FA cannot be disabled from the user admin page.
Discourse supports three types of 2-factor options: TOTP (6-digit codes rotating every 30 seconds), security key (Yubikey, biometric, etc.), and backup codes. Sometimes users will misconfigure their 2-factor device, lose or reset their phone, or otherwise no longer be able to use/obtain the 2-factor. Admins can then assist in reseting this for them.
Admins should be certain to verify that the user is the one making the request. Disabling 2-factor makes an account easier to hack, so be sure a bad party isnβt requesting the reset.
Disabling 2FA for a user
First, youβll need to know what user is having the issue. Get the username for the user:
Access the rails app on your server via ssh.
From your local machine:ssh root@=SERVER_IP=Go to the app directory:
cd /var/www/discourse sudo ./launcher enter app -
Use the provided rake task to disable all 2FA methods for the user:
bundle exec rake users:disable_2fa[=USERNAME=]This will remove all TOTP authenticators, security keys used for 2FA, and backup codes. Note that passkeys are not affected by this command.
Check document
Perform check on document:
