تعطيل إسناد كتلة التعليمات البرمجية للرسائل الإلكترونية
Many posts in my forums are created via email. They do not contain code.
Would appreciate a setting to turn off the four-character code-block feature of Markdown when the post originated from an email.
That is to prevent many email paragraphs being turned into code blocks due to paragraph indents.
11 إعجابًا
I wholeheartedly second this request with an extra :heart:.
إعجاب واحد (1)
hmmm … I thought we had incoming email prefer html and that is default on?
So you are saying you have people composing stuff in plain text mode and indenting?
Can you reply to this post via email with an example problem?
3 إعجابات
No, it’s the email client that’s adding these whitespaces (in the HTML version).
The actual bug is that our html-to-markdown library isn’t interpreting whitespace as well as the browser does.
https://medium.com/@patrickbrosset/when-does-white-space-matter-in-html-b90e8a7cdd33
It’s been on my TODO list since the inception of incoming email support.
9 إعجابات
We do have emails sent in text-only. Usually sent by people with older email systems, but that is not at all rare.
What is rare is email containing code fragments.
+1
I fully second this!
Ok, I’m old. I’m also a publisher of books (on paper and electronic). Books indent new paragraphs. In letters or emails that use this convention, a tab is used. I’ve looked through the posts on this topic and haven’t found if there is a way to allow tabs as a default. (Or at least allow 4 or 5 spaces to function as an indent.)
Is this possible without complicated programmin or plugins?
إعجاب واحد (1)
Yeah we have meant to work on this issue for quite a while now, thanks for the reminder, there is no setting now but we plan to sort this out.
5 إعجابات
Thanks for the prompt and encouraging reply. I’ve been very impressed by Discourse, and by the helpfulness of the community.
إعجاب واحد (1)
This will help a GREAT deal in getting much less messy emails!
I just submitted a pull request to introduce a new site setting strip incoming email lines . I did not want to completely disable code blocks when this setting is enabled, so code blocks will still be accepted between [code]…[/code] and ```…```, but all the other lines will be stripped (leading and trailing whitespaces will be removed).
For example, the following email:
MIME-Version: 1.0
Date: Tue, 01 Jan 2019 00:00:00 +0300
Subject: An email with whitespaces
To: bar@discourse.org
Content-Type: text/plain; charset="UTF-8"
Hello
    This is a line that will be stripped
    This is another line that will be stripped
This is a line that will not be touched.
This is another line that will not be touched.
[code]
  1.upto(10).each do |i|
    puts i
[/code]
    This is going to be stripped too.
Bye!
will produce the following reply:
Hello
    puts i
Bye!
disabling this setting will create the following reply:
Hello
    puts i
Bye!
8 إعجابات
Excellent! Thanks, Dan. This will clean up a large number of our incoming emails. :ok_hand:
3 إعجابات
Cool so the upshot of this setting is that traditional space indented commonmark code blocks become impossible, right? No other side effects? That seems like a reasonable tradeoff for sites that have the “random space indenting problem” :wink:
4 إعجابات
Unfortunately, no. Stripping every line also results in losing levels for nested lists.
* parent
  * child 1
  * child 2
becomes
* parent
* child 1
* child 2
6 إعجابات
A better way is probably to trap the code block recognition from the MarkDown engine and change the block type to normal text.
إعجابَين (2)
This is kind of an edge case behind a flag that has to be opted in. It’s not worth a ton of engineering, a “good enough” solution is fine.
إعجابَين (2)
Agree. Who uses multi-layer bullets anyway? Not many I predict.
إعجاب واحد (1)
Of course, that would be ideal, but it is a lot more effort than you would think.
Our “post cooking” (converting raw text to HTML) pipeline is quite complex and in the end it gets to MarkdownIt, which does not offer something such as a reverse mapping.
7 إعجابات
Or… Only strip leading white space if the first letter of the line is not an obvious bullet mark like * or -.
That still won’t solve the problem for multi-layer numbered lists but those should be very rare…
7 إعجابات
That is an excellent idea!
https://github.com/discourse/discourse/commit/35a866fe229ffe6a22b947a671c82c1bcc7dec51
7 إعجابات
