I’m running the docker install, imported a vbulletin database and finally got everything working. Unfortunately, the load times info still show up at the left-hand side of the screen. Is there a setting in the database that allows me to disable this?
Users are discussing how to disable the load time profiler (mini-profiler) displayed on the left margin of the screen in Discourse. apotry reports the issue after importing a vBulletin database via Docker. Chili advises setting DISCOURSE_LOAD_MINI_PROFILER: false in app.yml and rebuilding the app, noting that only developers see this info. thangngoc89 confirms it’s developer-only. Later, Cyclops reports that both ALT+P and the DISCOURSE_ENABLE_MINI_PROFILER: FALSE setting fail to hide the profiler — though users can’t see it, it bothers them when logged in. codinghorror confirms the regression and tags sam, who clarifies the correct setting is DISCOURSE_LOAD_MINI_PROFILER, not ENABLE. sam suspects a keyboard event issue in mini-profiler or Discourse. Cyclops thanks sam after the fix. Later users, including JohnMHarrisJr and codinghorror, confirm ALT+P no longer works. However, Varun_Deva reports ALT+P still works for them. The consensus is to use DISCOURSE_LOAD_MINI_PROFILER: false in app.yml to disable it reliably.
You can remove your account’s login email as one of the “DISCOURSE_DEVELOPER_EMAILS” in the app.yml
DISCOURSE_DEVELOPER_EMAILS: 'name@example.com'
Or, add the following:
And then run:
./launcher rebuild app
Also:
Only you, the developers can see that infomation.
Thanks, didn’t realize!
I know this is an old thread, but I tried the Alt-P option as well as adding the line to my app.yml file:
Neither worked, I’m glad to know my users cannot see it, but somehow it honestly bugs me to have it up there when I’m logged in. There any other options for how to disable this?
This does seem to have regressed @sam.
No, but the setting is called DISCOURSE_LOAD_MINI_PROFILER not DISCOURSE_ENABLE_MINI_PROFILER
Alt+P is not working to remove timings any more, just tested on discourse.codinghorror and confirmed.
I need to test if this is a breakage in mini profiler or discourse. I bet our keyboard thing is not floating up the event.
Thank you very, very much!
I know I’m resurrecting a dead thread here, but I’m having this exact issue (Alt+P not working)
ALT+P hasn’t worked for a while now cc @sam
ALT+P Worked for me
Thanks
