Disabling all emails except those registration related?
I have a client that wants to use Discourse on a project but cannot have Discourse emails coming through their email system for legal reasons. The instance of Discourse is going to be very heavily moderated/administered by some people in charge of the project. It seems there are two possible solutions here:
  • Admins create the accounts for the users and send them the credentials
  • Users receive only registration and password change emails and nothing else.
Right now, it doesn’t seem like either of those situations is possible. Am I correct in that assumption? Is there another way to establish and manage this community?
You could build a plugin that patches that area and makes the email notifications a no-op
Or you could totally disable emails and build a custom frontend for account management using the API
There is no built in way
SSO ftw.
Disable all emails, and set up a simple rails / Django app for user management, and reuse the SSO code for those frameworks.
I really can’t say how awesome discourse SSO is.
5 个赞
Yes, I totally endorse that, on second thought that is the best thing to do here instead of butchering Discourse internals with monkey patches.
5 个赞
Ok, awesome. Do you know if there’s any publicly available example of a SSO source for Discourse? A Rails or Django app that’s ready to go, so to speak? I’ve worked in both, but if there’s a “perfect working example” out there that I can clone and use, that would be super handy. :smiley:
1 个赞
The topic you are looking for is :arrow_right:
5 个赞
此主题已在 2892 天后自动关闭。不再允许回复。
