Of course Discobot’s quote feature is just “the icing on the cake” and not the cake itself, but is there a way to customize it to use our own quotes? Maybe by uploading a JSON file or so? We already have a random quote function on our website and would like to integrate those quotes in our Discourse forum as well. Thanks!
The discussion revolves around customizing Discobot’s quotes in Discourse forums. Vimala_Ayya inquired about using custom quotes by uploading a JSON file. codinghorror and zogstrip mentioned that quotes can be overridden in the config file and admin panel. However, Vimala_Ayya found that the bot fetches English quotes from an external API (http://api.forismatic.com/api/1.0/), which cannot be customized. tgxworld and Vimala_Ayya confirmed that there is no workaround for the English locale. Several users, including tophee, fearlessfrog, and outofthebox, suggested making the quote source customizable to allow admins to specify a file or settings for local quotes, which would be a great customization feature for the narrative bot.
Yes, this feature already exists in discobot, just look at the config file.
You can also override the quotes in Cutomize > Text Content and look for strings starting with “discourse_narrative_bot.quote”.
I changed those 10 quotes in the admin panel, which basically overrides the quotes here: discourse/plugins/discourse-narrative-bot/config/locales/server.en.yml at main · discourse/discourse · GitHub
But the bot seems to get it’s quotes from somewhere else, which I cannot find. … ![]()
We will need to ask @tgxworld
When you’re using the english locale, Discobot fetches the quotes from an external API http://api.forismatic.com/api/1.0/ which is only available in English. As a work around for other languages, we added 10 generic quotes so that they can be translated and used by the other locales.
That’s what I suspected. So no workaround for English then?
Nope. No work around currently for :en locale.
I think customizing the bot’s quotes to be more relevant to a specific community would be great. Would it be an option to make the source for the bot’s quotes customizable, i.e. that admins can specify a file from which the quotes are supposed to be selected?
Allowing a setting to pick local quotes would be great, as a nice simple customization of the narrative bot for sites to use.
I’d also like to be able to customize the discobot quotes to better fit my community (in English).
