Impossible de trouver le texte modifiable de Discobot ?
Following this tutorial here: Who is Discobot?
In my Admin>Customize>Text Content I only have 4 items and none are related to Discobot. I want to ask users to create a new post in the “introduction” section.
Side note. Is it possible to FORCE users to post an introduction?
There’s a plugin here:
… that you can have users post an introduction:
You can enter any translation key in the search bar and it will find it. The parent key for the narrative bot is discourse_narrative_bot.
You can find the text you want to edit quickly by doing a find on this file:
@KyleTryon, if you are on the latest version of Discouse there is a problem searching in the text content page. This is probably why you can not find the strings you need.
See https://meta.discourse.org/t/hitting-enter-key-not-working-in-the-full-page-search-and-in-the-text-context-page/79758/3?u=dax .
Thanks all,
Was able to get there using the work around.
Search discourse_narrative_bot.new_user_narrative.hello.message
Click away to a new page.
Click back in your browser.
Good to go!
