das-g
(Raphael Das Gupta)
1
With
the icon of the “more” menu of the composer toolbar was changed from a gear (
) to a circular disk with a plus (similar to ⊕, but inverted).
However, @discobot still talks about the gear in the advanced user tutorial:
Here are the English originals in the source code:
Lilly
(Lillian )
4
Hi @das-g thanks for the report. I alerted our team to this and we will get those strings updated.
chapoi
7
Thanks for the report on that oversight, fixed in
one1
9
Will this fix affect existing installs? Or do we need to make this change manually?
Edit to add: In our case we have not overridden the default.
chapoi
10
Yes, I think it should fix existing installs, when you update.
chapoi
Closed
11
This topic was automatically closed after 3 days. New replies are no longer allowed.
